Author Topic: Welder  (Read 1804 times)
Welder
« on: September 10, 2009, 05:18:38 PM »
Hey, guys, how many amps would you say is needed for some basic welding on the Jeep?  I just saw a Kawasaki welder here in Costa Rica in PriceSmart (Costco) that looks nice; it's under $200 (keep in mind prices here are typically twice that of the US!) and comes with head piece and gloves.  It is a spool welder, but does not have any setup for gas...  Suppossedly, it can weld UP TO 3/16 without issues, so I figured it would be a good "learning" wleder for me to try.  Thoughts?
Re: Welder
« Reply #1 on: September 10, 2009, 05:28:08 PM »
Gotta link?
I am using a Lincoln 135 with flux core. It does 99% of the welding I need. Flux burns hotter than MIG.
Re: Welder
« Reply #2 on: September 10, 2009, 05:32:19 PM »
Id save up for a welder that can use sheilding gas... they will weld better and you don't have to worry about finding flux core wire (aka when you bring it on a trip and forget the wire somehow)...
Re: Welder
« Reply #3 on: September 10, 2009, 06:36:46 PM »
What fourbanger said, 135Amp is probably good for what you need on the Jeep. I have a mastercraft that does both (gas and flux) but i rushed and got 80 amp which is only good for small jobs - if I were to do it again i would wait and get one that's over 100 and maybe look at a tig (even though for those you jump in price quite a bit).
definitely gas shielding is better way but there will be some extra cost: bottle is about $100 (aluminum), regulator another $60 or so and gas (which if i remember correctly would be around $30 for a refill for a co2+argon mix) - flux core is not that hard to find, it's fairly common nowadays only difference is that the polarity is reversed and i think (but not sure) that any mig would do flux as well just need to reverse the wires (mine has a big label where the spool goes warning to reverse the ground and gun wires for flux core welding).
Re: Welder
« Reply #4 on: September 10, 2009, 06:47:33 PM »
You have it right as far as polarity.
 If you want to weld with gas shield you need a machine that has more amps. Which put you into a 220V machine. I have run a gas bottle on the Lincoln 135 and the welds were pretty cold even with the settings maxed out. Not of very thick material either.
I love my Readywelder for the times I need more amps. Just need a couple of batteries. Prolly expensive to get in Costa Rica thou.
Re: Welder
« Reply #5 on: September 11, 2009, 08:18:08 AM »
The Kawasaki one was 80A IIRC, and there was also this one, with gas, but it is 70A (by the way, this one costs about $460!).  I guess I'll pass.  It's probably cheaper here to hire someone to do the welding for me than to buy a machine (labor is cheap down here).
