Author Topic: Jeep 2.4L throttlebody swap  (Read 3957 times)
4bddn
« on: September 12, 2009, 07:36:45 AM »
New to this frum, so if this question has been asked...my apologies.  Ive got the 2.4L and I see lots of articles about swapping a 4.0L tb on the 2.5L motor...but nothing on doing the same with the 2.4L.  Is this even possible?  Thanks
Re: Jeep 2.4L throttlebody swap
« Reply #1 on: September 12, 2009, 07:48:36 AM »
if i remember correctly the 2.4l has a different bolt pattern for the tb so it wont work....
4bddn
« Reply #2 on: September 12, 2009, 08:20:46 AM »
snap...thats not what i wanted to hear  :'(
« Reply #3 on: September 12, 2009, 10:10:25 AM »
if that's the only problem (difference) you can always make an adapter (e.g. something like the spacer with countersunk holes for the intake bolts and threaded holes for the t/b - a piece of 1/2'' aluminum will do) - but question is will the other things bolt right in: tps, map, IAC?
« Reply #4 on: September 12, 2009, 10:14:45 AM »
I would look toward other Chrysler products, maybe with a turbo 2.4L or otherwise, and see if they have a larger TB that will swap on.
« Reply #5 on: September 12, 2009, 10:30:45 AM »
Look for pt cruiser soup up stuff. Or some parts of the 2 door chrysler sports thing cannot think of the name right now is a little sportscar with a turbo 2.4
Still the little 2.4 does alright as it is
« Reply #6 on: September 12, 2009, 11:47:55 AM »
dodge neon maybe (i mean if that's what you were thinking of)?
4bddn
« Reply #7 on: September 12, 2009, 01:07:53 PM »
i know only of the jeep 4.0 tb dimensions.  i htink they are a 58mm bore.  any ideas on the pt cruiser or neons?
« Reply #8 on: September 12, 2009, 01:59:04 PM »
srt4 aka neon
« Reply #10 on: September 13, 2009, 12:24:57 PM »
80mm sounds a bit big for a 2.4L four, but who knows.  I'd be weary of the following in the Ebay auction:
Quote
# Universal fit to most car, come with adapter plate that you can weld on a intake manifold.
# Included a place to bolt on TPS (Throttle position sensor).
# No instructions included. Professional installation is highly recommended.
4bddn
« Reply #11 on: September 14, 2009, 07:10:38 AM »
i agree.  more of a comparison of tb's just to get an idea of things.  i think the upgraded tbs are  62mm...much smaller than the 80mm on ebay!  but, ive seen going from a 2.5L tb toa 4.0L tb, just never anything about the 2.4L
