Author Topic: WAT THE F!!!!  (Read 1775 times)
93yjFirstJeep
WAT THE F!!!!
« on: September 12, 2009, 04:33:26 PM »
So i just put in my new 4.0tb and its revved to 6k before i changed the ais housing over, so i changed it over and now its idleing at 3500 to 4k, i reset the computer and swapped everything, WHAT THE F IS WRONG!!!!  :brick:
93yjFirstJeep
Re: WAT THE F!!!!
« Reply #1 on: September 12, 2009, 05:23:28 PM »
so the 4 bolts that hold on the throttle body were loose so i tightened them, then it idled about 1500, so i took out the ais motor and cleaned the plunger, now it idles about 1400 and it has a really loud whistling sound  :brick:  :brick:  :brick:
Tsd
Re: WAT THE F!!!!
« Reply #2 on: September 12, 2009, 05:46:40 PM »
I think there is a "waiting time" involved so the computer can reprogram itself. For what i have read you have to drive a few miles so that the computer can re-learn all the data.
Check the FAQ, Jeffy wrote a write up about this subject:
http://4bangerjp.com/forums/index.php/topic,8.0.html
« Last Edit: September 12, 2009, 05:51:34 PM by Tsd »
93yjFirstJeep
Re: WAT THE F!!!!
« Reply #3 on: September 12, 2009, 05:51:41 PM »
Well there was a crack in the body itself from something that wasnt letting me tighten the ais housing, so i just hit it with a hammer until it was back to normal and now it works
Tsd
Re: WAT THE F!!!!
« Reply #4 on: September 12, 2009, 05:53:36 PM »
Well.... "if you can't fix it...you need a bigger hammer"   :lol:
Glad you worked it out.
