Author Topic: Flywheel installed wrong?  (Read 1562 times)
dono man
« on: September 19, 2009, 10:47:07 AM »
I've searched around and found that you can NOT install the flywheel in the wrong position. This is on a 97 2.5L.
Can anybody verify this for me?
thanks
Re: Flywheel installed wrong?
« Reply #1 on: September 19, 2009, 12:40:50 PM »
thanks
as long as all the bolts that go in the crankshaft will thread in by hand and not go in crooked you are right on the money - the holes in the flywheel and crank are keyed (not equally spaced) for that reason.
jdarg
« Reply #2 on: September 24, 2009, 01:51:13 PM »
x2...one of the bolts in the circular pattern is slightly off so its not possible to do it wrong. I just did mine this past winter and ended up w/ a stripped a hole in the crank putting it together  :brick: so its still fresh in my mind.
dono man
« Reply #3 on: September 29, 2009, 07:30:14 PM »
That's what I thought and hoped. Thanks
