Author Topic: yj with no go  (Read 7335 times)
YJ KiD
Re: yj with no go
« Reply #15 on: September 23, 2009, 09:49:36 PM »
with the injector swap is changing the injectors them selves all u have to do . . . .there isnt anything else to do(spark plugs, etc.) thanks for all the info in advance
Re: yj with no go
« Reply #16 on: September 24, 2009, 12:14:54 AM »
you should get a 4.0L throttle body (not sure if you have it yet or suggested before in this thread - so if it was please disregard this, there are a few write-ups on this site regarding that) and match the diameter in the intake port where it bolts on. You can get one fairly cheap at a wreckers, mine came off a Cherokee. Also a cold air intake or high flow air filter combined with removing the velocity (or whatever it's called) restrictor tube in the air filter box cover
YJ KiD
Re: yj with no go
« Reply #17 on: September 25, 2009, 08:09:47 PM »
what about goin to a 62mm from the vendos forum?
Re: yj with no go
« Reply #18 on: September 25, 2009, 08:13:39 PM »
Get one from Bounty Hunter, great guy, fast service plus he's one of us!
YJ KiD
Re: yj with no go
« Reply #19 on: September 25, 2009, 08:42:54 PM »
was planning on it that is why i asked if my stock 2.5 tb would count as the core or i had to come up with a 4.0 tb in the vendors form  . . . ..sorry for the confusion
« Last Edit: September 25, 2009, 08:44:53 PM by YJ KiD »
Re: yj with no go
« Reply #20 on: September 25, 2009, 08:45:43 PM »
Your 2.5 TB will make a perfect core. I sent him mine when I got a 62MM one from him.
