Author Topic: throttle body spacer  (Read 2176 times)
cab
« on: September 29, 2009, 08:25:05 AM »
  thinking about adding a spacer.  anybody know anything about the jet performance powr-flo spacers?  any what about a cold air intake?  getting cool enough here to start wrenching on the jeep.  o i have a 89 yj with the massive 2.5 and no im not going to do a engine swap!
dos0711
Re: throttle body spacer
« Reply #1 on: September 29, 2009, 08:59:42 AM »
You'd get more out of going to an electric fan...
« Reply #2 on: September 29, 2009, 10:14:10 AM »
I think BountyHunter sells the spacers, right?  I know he sells the 62mm TB, not 100% sure on the spacers...
« Reply #3 on: September 29, 2009, 10:31:57 AM »
I have 62mm TB's and spacers, but only for '91-'04 2.5L and 4.0L engines.  I don't know of anything for the early TBI 2.5L engine.
« Reply #4 on: September 29, 2009, 02:25:37 PM »
none makes a throttle body spacer for the tbi 2.5l... gaurdian7 was experimenting with making them then lost interest aka sold  his tbi for a mpfi 2.5l jeep.  he did offer to make me one for $50 when i was contemplating on making one myself (that was 2 years ago).. i passed up the offer as i ran out of time and interest at that point.... so you may want to contact gardian7 if you don't have a means of making one yourself.
cab
« Reply #5 on: September 29, 2009, 03:14:37 PM »
  What about this?
Castr8r
« Reply #6 on: September 30, 2009, 10:28:17 PM »
My two cents worth-  that's what the throttle body spacer is worth.  I made one for my TBI banger and I wouldn't bother if I had it to do over.  The best thing you can do to your intake manifold is to clean it up- clear out the "dingleberries" and match the inlet to the TB.  If you insist on having one, I used a chunk of 1" thick aluminum plate welded to the manifold.
« Reply #7 on: October 01, 2009, 11:26:13 PM »
With my cam and engine mods the spacer is huge, moves the power band very predictably.
Without the spacer my engine hits at about 3500.
With it at 2500.
Spacer out for the sand, in for everything else...
