Author Topic: auto tranny symptoms  (Read 7124 times)
drunkencityworker
Re: auto tranny symptoms
« Reply #15 on: January 14, 2010, 09:09:49 AM »
Thanks oldjeep...looks like I will be trying to rebuild a spare...and yes at times I have been known to be a drunken monkey....usually round st pattys day is a good bet
« Reply #16 on: January 14, 2010, 10:15:48 AM »
Just make sure you spend the $20 for an atsg manual and you'll do fine.  You need to be a little creative with the clutch packs, since no home user actually owns the tools that they call out.  Usually a press or some all thread and scrap steel are enough to make your own compressors.
I've done a 904, Th400's, aw4 and C6.  None of them have required tools that couldn't be jury rigged with what was laying around.  (Except for an accurate torque wrench for soing the band adjustments)
« Last Edit: January 14, 2010, 10:16:36 AM by oldjeep »
« Reply #17 on: January 14, 2010, 11:51:25 AM »
how deep does water/mud have to be for me to seriously consider relocating the vents? are we talking anything above the midpoint of the wheel or deeper...maybe less? i certainly dont want to have to go through this again..but im also not sure if any of the wheeling ive done contributed to it.
« Reply #18 on: January 14, 2010, 12:00:22 PM »
The vent is inside the bellhousing about 5" above the centerline of the input shaft.  So pretty deep
« Reply #19 on: January 14, 2010, 01:50:25 PM »
i asked the tranny shop guy about relocating the vent and he said it cant be done on an auto due to the location of the vent. this is a common mod for manual trans. he said he found mud/sand inside when he opened it up..so apparently ive been in deep enough water.
« Reply #20 on: January 14, 2010, 02:08:33 PM »
It's well documented how to relocate the vent on the jeep auto.  I can understand why a tranny shop wouldn't want to do it though.
« Reply #21 on: January 14, 2010, 02:21:29 PM »
i assume it would have to be redropped?
drunkencityworker
« Reply #22 on: January 14, 2010, 02:49:19 PM »
Yea has to be dropped...did you click on linky I put up for it...Another way is to put a 90 in original vent and drill hole in bellhousing to keep tube from hitting torque converter... If he founf that stuff in trans I would def get rid of stock trans cooler its really small and will block up easily and will cause fluid to burn up
« Reply #23 on: January 14, 2010, 04:03:07 PM »
yea i checked the links, thanks for putting them up. How else can i prevent mud or sand or water from getting in there?
« Reply #24 on: January 14, 2010, 04:06:44 PM »
Stay out of the deep mud and water  :lol:
« Reply #25 on: January 14, 2010, 04:14:05 PM »
@drunkencityworker: you should do a writeup when you rebuild your spare, i have a manual but would be great info for the guys running autos, could end up in the faq maybe - since according to the info oldjeep provided would cost nowhere near $1,300 to rebuild it (including the TC)
drunkencityworker
« Reply #26 on: January 15, 2010, 05:27:06 AM »
yea sounds like a good idea. I will let you know when I get at that.
sorry onlyway to relocate vent is to drop the trans. It realy isnt that bad. A weekend project at most. unbolt and bolt back up. A tranny jack and a hand for some muscle is all you need.
« Reply #27 on: January 15, 2010, 12:40:54 PM »
yea, i def dont want anymore problems..ill have to look into getting a buddy or two and getting this done
