Author Topic: 95 YJ Clutch Problems....  (Read 1998 times)
4BangN
« on: February 27, 2010, 10:02:37 PM »
So I'm driving to dinner tonight. And as I go to pull into the parking lot I push in the clutch and take it out of gear.. As I pushed in the clutch I realized that there wasn't any pressure on the peddle. So I stroll into a parking spot and pop the hood. I don't see any fluid leaking anywhere. so I get under the Jeep and look for the clutch fork and it is built into the bell housing so I can't see anything.
I check the reservoir and I am full of fluid. I check the peddle and there is a small leak at the peddle. So I'm thinking maybe the master cylinder is shot or my pressure plate fell apart.
Any ideas  :puzzled:
Re: 95 YJ Clutch Problems....
« Reply #1 on: February 27, 2010, 10:18:22 PM »
Odd, the 95 should be an external slave on the driver side.
Usually I replace them as a set. My 94 has the original units, 235K Miles.... :)
95yjman
« Reply #2 on: February 27, 2010, 10:20:09 PM »
yep should be external slave, and it very well could be the clutch master cyl.  I've had to replace both on my 95...
4BangN
« Reply #3 on: February 28, 2010, 10:51:56 AM »
I am hoping I can figure this out rather quickly..  But we will have to wait and see how things work out.  I won't know anything until I get the jeep moved on monday.  And then maybe by thursday I can have it figured out.
Thanks for all the help so far.
4BangN
« Reply #4 on: March 01, 2010, 11:03:23 PM »
Master cylinder was bad.  Changed it, bleed it..  Good to go..  Thanks for all the help..
