Author Topic: A Chart of Fuel Injector Flow rates  (Read 7248 times)
Complete Loser
« on: March 15, 2010, 10:20:59 PM »
http://www.fuelinjector.citymaker.com/Fuel_Injector_Flow_Rates.html
Would be super kewl if someone could do the math on these (converted to 39psi fuel pressure). But im sure thats a tall order. lol
Re: A Chart of Fuel Injector Flow rates
« Reply #1 on: March 16, 2010, 01:15:53 AM »
use this http://www.csgnetwork.com/fiflowcalc.html and you can get the result you're looking for
EDIT: although would be easier to convert what you're looking for to 43.5 and then look for something close to that in the table you posted. also keep in mind you need high impedance and EV1 connector type
or if you really want to convert all those to 39 psi you can always use an excel spreadsheet and put the formula from the faq in there to do the conversion.
« Last Edit: March 16, 2010, 01:25:13 AM by sharpxmen »
Complete Loser
« Reply #2 on: March 16, 2010, 08:44:15 AM »
Kewl, thanks.  :beers:
« Reply #3 on: March 16, 2010, 09:22:24 AM »
got it done in excel, not sure how it will come out in here but let's try:
i had to split the table as it exceeds the length otherwise
   BOSCH      LBS/HR      CC/MIN      GRAMS      PSI      BAR      39psi flow      49psi flow
   0-280-150-001      25.2      264.9      190.5      43.5      3      23.86      26.75
   0-280-150-002      25.2      264.9      190.5      43.5      3      23.86      26.75
   0-280-150-003      36.15      379.9      273.3      43.5      3      34.23      38.37
   0-280-150-007      25.2      264.9      190.5      43.5      3      23.86      26.75
   0-280-150-008      25.2      264.9      190.5      43.5      3      23.86      26.75
   0-280-150-009      25.2      264.9      190.5      43.5      3      23.86      26.75
   0-280-150-015      36.15      379.9      273.3      43.5      3      34.23      38.37
   0-280-150-023      33.5      352.1      253.3      43.5      3      31.72      35.55
   0-280-150-024      36.15      379.9      273.3      43.5      3      34.23      38.37
   0-280-150-026      36.15      379.9      273.3      43.5      3      34.23      38.37
   0-280-150-035      30.5      320.6      230.6      29      2      35.37      39.65
   0-280-150-036      36.15      379.9      273.3      43.5      3      34.23      38.37
   0-280-150-041      45.7      480.3      345.5      43.5      3      43.27      48.50
   0-280-150-043      36.15      379.9      273.3      43.5      3      34.23      38.37
   0-280-150-044      32.15      337.9      243      -      -       -        -
   0-280-150-045      38.1      400.4      288      -      -       -        -
   0-280-150-100      17.6      185      133.1      43.5      3      16.66      18.68
   0-280-150-105      18.1      190.2      136.8      43.5      3      17.14      19.21
   0-280-150-112      18.1      190.2      136.8      -      -       -        -
   0-280-150-114      18.1      190.2      136.8      -      -       -        -
   0-280-150-116      18.1      190.2      136.8      -      -       -        -
   0-280-150-117      18.1      190.2      136.8      -      -       -        -
   0-280-150-118      18.1      190.2      136.8      -      -       -        -
   0-280-150-119      18.1      190.2      136.8      -      -       -        -
   0-280-150-121      16.95      178.1      128.1      43.5      3      16.05      17.99
   0-280-150-123      18.2      191.3      137.6      -      -       -        -
   0-280-150-125      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-150-126      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-150-128      15.9      167.1      120.2      43.5      3      15.06      16.88
   0-280-150-129      18.2      191.3      137.6      -      -       -        -
   0-280-150-130      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-150-133      18.2      191.3      137.6      -      -       -        -
   0-280-150-135      18.2      191.3      137.6      -      -       -        -
   0-280-150-136      18.2      191.3      137.6      -      -       -        -
   0-280-150-150      18.1      190.2      136.8      43.5      3      17.14      19.21
   0-280-150-151      22.9      240.7      173.1      29      2      26.56      29.77
   0-280-150-151      29      304.8      219.2      43.5      3      27.46      30.78
   0-280-150-152      22.5      236.5      170.1      -      -       -        -
   0-280-150-153      22.5      236.5      170.1      43.5      3      21.30      23.88
   0-280-150-154      22.5      236.5      170.1      43.5      3      21.30      23.88
   0-280-150-157      20.4      214.4      154.2      36.25      2.5      21.16      23.72
   0-280-150-158      21.8      229.1      164.8      36.25      2.5      22.61      25.35
   0-280-150-159      24.35      255.9      184.1      -      -       -        -
   0-280-150-160      17.6      185      133.1      -      -       -        -
   0-280-150-161      17.2      180.8      130      43.5      3      16.29      18.26
   0-280-150-162      17.2      180.8      130      43.5      3      16.29      18.26
   0-280-150-163      17.2      180.8      130      43.5      3      16.29      18.26
   0-280-150-164      17.2      180.8      130      43.5      3      16.29      18.26
   0-280-150-165      22.2      233.3      167.8      43.5      3      21.02      23.56
   0-280-150-166      20.3      213.4      153.5      43.5      3      19.22      21.55
   0-280-150-200      28.6      300.6      216.2      43.5      3      27.08      30.35
   0-280-150-201      22.5      236.5      170.1      36.25      2.5      23.34      26.16
   0-280-150-201      24.55      258      185.6      43.5      3      23.25      26.06
   0-280-150-203      17.6      185      133.1      36.25      2.5      18.26      20.46
   0-280-150-204      16      168.2      121      36.25      2.5      16.60      18.60
   0-280-150-205      16.2      170.3      122.5      36.25      2.5      16.80      18.83
   0-280-150-206      16      168.2      121      36.25      2.5      16.60      18.60
   0-280-150-207      16.3      171.3      123.2      36.25      2.5      16.91      18.95
   0-280-150-208      12.65      133      95.68      36.25      2.5      13.12      14.71
   0-280-150-208      13.7      144      103.6      39.15      2.7      13.67      15.33
   0-280-150-209      15.9      167.1      120.2      36.25      2.5      16.49      18.49
   0-280-150-209      16.75      176      126.6      43.5      3      15.86      17.78
   0-280-150-210      12.65      133      95.68      36.25      2.5      13.12      14.71
   0-280-150-211      14      147.1      105.8      43.5      3      13.26      14.86
   0-280-150-213      33      346.8      249.5      43.5      3      31.25      35.02
   0-280-150-214      17.9      188.1      135.3      43.5      3      16.95      19.00
   0-280-150-215      20.4      214.4      154.2      36.25      2.5      21.16      23.72
   0-280-150-216      20.4      214.4      154.2      36.25      2.5      21.16      23.72
   0-280-150-217      16      168.2      121      36.25      2.5      16.60      18.60
   0-280-150-218      29.7      312.1      224.5      45      3.1      27.65      30.99
   0-280-150-219      16      168.2      121      36.25      2.5      16.60      18.60
   0-280-150-220      14.1      148.2      106.6      43.5      3      13.35      14.96
   0-280-150-221      14.1      148.2      106.6      43.5      3      13.35      14.96
   0-280-150-222      16      168.2      121      36.25      2.5      16.60      18.60
   0-280-150-223      21.35      224.4      161.4      36      2.48      22.22      24.91
   0-280-150-226      18.2      191.3      137.6      -      -       -        -
   0-280-150-227      18.2      191.3      137.6      -      -       -        -
   0-280-150-230      17.5      183.9      132.3      -      -       -        -
   0-280-150-231      14.1      148.2      106.6      -      -       -        -
   0-280-150-233      14.1      148.2      106.6      -      -       -        -
   0-280-150-234      18.1      190.2      136.8      43.5      3      17.14      19.21
   0-280-150-235      18.1      190.2      136.8      43.5      3      17.14      19.21
   0-280-150-237      14.55      152.9      110      43.5      3      13.78      15.44
   0-280-150-238      18.1      190.2      136.8      43.5      3      17.14      19.21
   0-280-150-239      21.35      224.4      161.4      36      2.48      22.22      24.91
   0-280-150-252      24.75      260.1      187.1      -      -       -        -
   0-280-150-254      24.75      260.1      187.1      36.25      2.5      25.67      28.78
   0-280-150-255      24.35      255.9      184.1      -      -       -        -
   0-280-150-257      18.1      190.2      136.8      43.5      3      17.14      19.21
   0-280-150-300      18.1      190.2      136.8      43.5      3      17.14      19.21
   0-280-150-302      18.1      190.2      136.8      43.5      3      17.14      19.21
   0-280-150-303      18.1      190.2      136.8      43.5      3      17.14      19.21
   0-280-150-306      49.5      520.2      374.2      43.5      3      46.87      52.54
   0-280-150-309      18.1      190.2      136.8      43.5      3      17.14      19.21
   0-280-150-310      18.1      190.2      136.8      43.5      3      17.14      19.21
   0-280-150-314      18.1      190.2      136.8      43.5      3      17.14      19.21
   0-280-150-315      18.1      190.2      136.8      43.5      3      17.14      19.21
   0-280-150-318      18.1      190.2      136.8      43.5      3      17.14      19.21
   0-280-150-319      18.1      190.2      136.8      43.5      3      17.14      19.21
   0-280-150-320      18.1      190.2      136.8      43.5      3      17.14      19.21
   0-280-150-321      18.1      190.2      136.8      43.5      3      17.14      19.21
   0-280-150-322      18.1      190.2      136.8      43.5      3      17.14      19.21
   0-280-150-323      18.1      190.2      136.8      43.5      3      17.14      19.21
   0-280-150-324      18.1      190.2      136.8      43.5      3      17.14      19.21
   0-280-150-325      18.1      190.2      136.8      43.5      3      17.14      19.21
   0-280-150-326      18.1      190.2      136.8      43.5      3      17.14      19.21
   0-280-150-327      18.1      190.2      136.8      43.5      3      17.14      19.21
   0-280-150-334      18.1      190.2      136.8      43.5      3      17.14      19.21
   0-280-150-335      28.6      300.6      216.2      43.5      3      27.08      30.35
   0-280-150-351      71      746.2      536.8      43.5      3      67.23      75.35
   0-280-150-352      25.7      270.1      194.3      43.5      3      24.33      27.28
   0-280-150-355      37      388.9      279.7      -      -       -        -
   0-280-150-355      28.6      300.6      216.2      43.5      3      27.08      30.35
   0-280-150-357      28.6      300.6      216.2      43.5      3      27.08      30.35
   0-280-150-360      25.7      270.1      194.3      43.5      3      24.33      27.28
   0-280-150-361      26.9      282.7      203.4      43.5      3      25.47      28.55
   0-280-150-362      25.7      270.1      194.3      43.5      3      24.33      27.28
   0-280-150-363      71      746.2      536.8      43.5      3      67.23      75.35
   0-280-150-364      25.7      270.1      194.3      43.5      3      24.33      27.28
   0-280-150-365      25.7      270.1      194.3      43.5      3      24.33      27.28
   0-280-150-368      25.5      268      192.8      43.5      3      24.15      27.06
   0-280-150-369      25.5      268      192.8      43.5      3      24.15      27.06
   0-280-150-400      41.6      437.2      314.5      43.5      3      39.39      44.15
   0-280-150-400      46      483.5      347.8      -      -       -        -
   0-280-150-401      41.6      437.2      314.5      43.5      3      39.39      44.15
   0-280-150-402      32.15      337.9      243      43.5      3      30.44      34.12
   0-280-150-402      37      388.9      279.7      -      -       -        -
   0-280-150-403      47.9      503.4      362.1      43.5      3      45.35      50.84
   0-280-150-403      52      546.5      393.1      -      -       -        -
   0-280-150-413      18.65      196      141      -      -       -        -
   0-280-150-414      14.65      154      110.8      -      -       -        -
   0-280-150-415      18.1      190.2      136.8      50.75      3.5      15.87      17.79
   0-280-150-416      14.25      149.8      107.7      -      -       -        -
   0-280-150-417      14.25      149.8      107.7      -      -       -        -
   0-280-150-418      25      262.8      189      -      -       -        -
   0-280-150-419      18.9      198.6      142.9      -      -       -        -
   0-280-150-420      28.9      303.7      218.5      -      -       -        -
   0-280-150-421      18.25      191.8      138      -      -       -        -
   0-280-150-422      24.9      261.7      188.2      39.15      2.7      24.85      27.86
   0-280-150-423      18.65      196      141      -      -       -        -
   0-280-150-424      16.5      173.4      124.7      -      -       -        -
   0-280-150-425      16.5      173.4      124.7      -      -       -        -
   0-280-150-427      22.95      241.2      173.5      -      -       -        -
   0-280-150-428      18.65      196      141      -      -       -        -
   0-280-150-429      18.65      196      141      -      -       -        -
   0-280-150-431      34.15      358.9      258.2      -      -       -        -
   0-280-150-431      33.3      350      251.7      43.5      3      31.53      35.34
   0-280-150-432      22.85      240.2      172.7      -      -       -        -
   0-280-150-432      23.8      250.1      179.9      43.5      3      22.54      25.26
   0-280-150-433      22.85      240.2      172.7      -      -       -        -
   0-280-150-438      16.25      170.8      122.8      -      -       -        -
   0-280-150-439      16      168.2      121      -      -       -        -
   0-280-150-440      23.8      250.1      179.9      50.75      3.5      20.86      23.39
   0-280-150-441      19.3      202.8      145.9      -      -       -        -
   0-280-150-442      19.3      202.8      145.9      -      -       -        -
   0-280-150-443      18.25      191.8      138      -      -       -        -
   0-280-150-444      14.25      149.8      107.7      -      -       -        -
   0-280-150-445      14.25      149.8      107.7      -      -       -        -
   0-280-150-446      16.75      176      126.6      -      -       -        -
   0-280-150-447      22.9      240.7      173.1      -      -       -        -
   0-280-150-448      22.9      240.7      173.1      -      -       -        -
   0-280-150-449      22.9      240.7      173.1      -      -       -        -
   0-280-150-450      31.9      335.3      241.2      -      -       -        -
   0-280-150-452      22.85      240.2      172.7      -      -       -        -
   0-280-150-453      26      273.3      196.6      -      -       -        -
   0-280-150-454      18.2      191.3      137.6      -      -       -        -
   0-280-150-455      21      220.7      158.8      -      -       -        -
   0-280-150-456      18.2      191.3      137.6      -      -       -        -
   0-280-150-457      14.25      149.8      107.7      -      -       -        -
   0-280-150-458      14.25      149.8      107.7      -      -       -        -
   0-280-150-459      15.6      164      117.9      -      -       -        -
   0-280-150-460      15.6      164      117.9      -      -       -        -
   0-280-150-461      22.85      240.2      172.7      -      -       -        -
   0-280-150-462      22.55      237      170.5      -      -       -        -
   0-280-150-463      18.25      191.8      138      -      -       -        -
   0-280-150-464      23.7      249.1      179.2      -      -       -        -
   0-280-150-465      23.7      249.1      179.2      -      -       -        -
   0-280-150-466      26      273.3      196.6      -      -       -        -
   0-280-150-467      26      273.3      196.6      -      -       -        -
   0-280-150-468      21      220.7      158.8      -      -       -        -
   0-280-150-469      21      220.7      158.8      -      -       -        -
   0-280-150-500      18.25      191.8      138      -      -       -        -
   0-280-150-500      20.15      211.8      152.3      43.5      3      19.08      21.39
   0-280-150-501      18.25      191.8      138      -      -       -        -
   0-280-150-502      22.85      240.2      172.7      -      -       -        -
   0-280-150-503      18.25      191.8      138      -      -       -        -
   0-280-150-503      20.15      211.8      152.3      43.5      3      19.08      21.39
   0-280-150-504      22.85      240.2      172.7      -      -       -        -
   0-280-150-505      18.25      191.8      138      -      -       -        -
   0-280-150-506      22.85      240.2      172.7      -      -       -        -
   0-280-150-507      22.85      240.2      172.7      -      -       -        -
   0-280-150-509      16.5      173.4      124.7      -      -       -        -
   0-280-150-550      26      273.3      196.6      -      -       -        -
   0-280-150-551      14.25      149.8      107.7      -      -       -        -
   0-280-150-552      14.25      149.8      107.7      -      -       -        -
   0-280-150-553      26      273.3      196.6      -      -       -        -
   0-280-150-554      26      273.3      196.6      -      -       -        -
   0-280-150-555      9.6      100.9      72.62      -      -       -        -
   0-280-150-556      18.25      191.8      138      -      -       -        -
   0-280-150-556      20      210.2      151.2      43.5      3      18.94      21.23
   0-280-150-557      20      210.2      151.2      43.5      3      18.94      21.23
   0-280-150-558      40      420.4      302.4      43.5      3      37.87      42.45
   0-280-150-559      39.75      417.8      300.5      -      -       -        -
   0-280-150-560      20      210.2      151.2      43.5      3      18.94      21.23
   0-280-150-561      22      231.2      166.3      -      -       -        -
   0-280-150-588      40      420.4      302.4      -      -       -        -
   0-280-150-601      48.5      509.7      366.7      36.25      2.5      50.31      56.39
   0-280-150-608      42      441.4      317.5      36.25      2.5      43.56      48.83
   0-280-150-614      18      189.2      136.1      43.5      3      17.04      19.10
   0-280-150-651      78      819.8      589.7      43.5      3      73.86      82.78
   0-280-150-653      98      1030      740.9      43.5      3      92.79      104.01
   0-280-150-655      98      1030      740.9      43.5      3      92.79      104.01
   0-280-150-657      81      851.3      612.3      43.5      3      76.70      85.97
   0-280-150-701      22.85      240.2      172.7      -      -       -        -
   0-280-150-701      21.5      226      162.5      43.5      3      20.36      22.82
   0-280-150-702      18      189.2      136.1      43.5      3      17.04      19.10
   0-280-150-703      14.2      149.2      107.4      43.5      3      13.45      15.07
   0-280-150-704      16.2      170.3      122.5      43.5      3      15.34      17.19
   0-280-150-705      14.35      150.8      108.5      -      -       -        -
   0-280-150-706      20.35      213.9      153.8      36.25      2.5      21.11      23.66
   0-280-150-707      18.25      191.8      138      36.25      2.5      18.93      21.22
   0-280-150-708      14.35      150.8      108.5      36.25      2.5      14.88      16.68
   0-280-150-710      13.5      141.9      102.1      36.25      2.5      14.00      15.70
   0-280-150-711      18.25      191.8      138      -      -       -        -
   0-280-150-712      20.35      213.9      153.8      36.25      2.5      21.11      23.66
   0-280-150-714      20.35      213.9      153.8      -      -       -        -
   0-280-150-714      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-150-715      14.5      152.4      109.6      43.5      3      13.73      15.39
   0-280-150-716      12.75      134      96.43      43.5      3      12.07      13.53
   0-280-150-718      19      199.7      143.6      32      2.21      20.98      23.51
   0-280-150-719      14.4      151.3      108.9      43.5      3      13.63      15.28
   0-280-150-720      14.4      151.3      108.9      43.5      3      13.63      15.28
   0-280-150-721      18.2      191.3      137.6      43.5      3      17.23      19.32
   0-280-150-722      18.2      191.3      137.6      43.5      3      17.23      19.32
   0-280-150-725      16.4      172.4      124      36.25      2.5      17.01      19.07
   0-280-150-726      18.65      196      141      -      -       -        -
   0-280-150-727      14      147.1      105.8      33      2.28      15.22      17.06
   0-280-150-728      24      252.2      181.4      43      2.96      22.86      25.62
   0-280-150-729      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-150-730      18.45      193.9      139.5      43.5      3      17.47      19.58
   0-280-150-731      18.45      193.9      139.5      43.5      3      17.47      19.58
   0-280-150-734      19.05      200.2      144      36.25      2.5      19.76      22.15
   0-280-150-736      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-150-737      29      304.8      219.2      43.5      3      27.46      30.78
   0-280-150-738      29      304.8      219.2      -      -       -        -
   0-280-150-740      14.25      149.8      107.7      43.5      3      13.49      15.12
   0-280-150-741      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-150-742      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-150-743      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-150-744      20.4      214.4      154.2      36.25      2.5      21.16      23.72
   0-280-150-745      22.35      234.9      169      -      -       -        -
   0-280-150-746      26.35      276.9      199.2      -      -       -        -
   0-280-150-747      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-150-748      14.35      150.8      108.5      43.5      3      13.59      15.23
   0-280-150-749      20.75      218.1      156.9      -      -       -        -
   0-280-150-749      18.85      198.1      142.5      43.5      3      17.85      20.01
   0-280-150-750      13.15      138.2      99.46      -      -       -        -
   0-280-150-751      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-150-752      14.2      149.2      107.4      43.5      3      13.45      15.07
   0-280-150-754      22.65      238.1      171.2      -      -       -        -
   0-280-150-756      30.55      321.1      231      43.5      3      28.93      32.42
   0-280-150-756      32      336.3      241.9      45      3.1      29.79      33.39
   0-280-150-757      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-150-758      22.85      240.2      172.7      -      -       -        -
   0-280-150-759      21.5      226      162.5      39.15      2.7      21.46      24.05
   0-280-150-760      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-150-761      22.65      238.1      171.2      -      -       -        -
   0-280-150-762      20.35      213.9      153.8      43.5      3      19.27      21.60
   0-280-150-763      17.9      188.1      135.3      43.5      3      16.95      19.00
   0-280-150-764      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-150-766      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-150-767      13.15      138.2      99.46      -      -       -        -
   0-280-150-767      17.9      188.1      135.3      43.5      3      16.95      19.00
   0-280-150-769      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-150-770      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-150-771      14.35      150.8      108.5      43.5      3      13.59      15.23
   0-280-150-773      14.25      149.8      107.7      43.5      3      13.49      15.12
   0-280-150-774      18.5      194.4      139.9      -      -       -        -
   0-280-150-775      18.65      196      141      47.9      3.3      16.83      18.86
   0-280-150-776      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-150-777      26.35      276.9      199.2      -      -       -        -
   0-280-150-778      18.15      190.8      137.2      43.5      3      17.19      19.26
   0-280-150-779      19      199.7      143.6      43.5      3      17.99      20.17
   0-280-150-783      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-150-784      28.85      303.2      218.1      -      -       -        -
   0-280-150-785      29.5      310      223      57      3.93      24.40      27.35
   0-280-150-786      22.15      232.8      167.5      43.5      3      20.97      23.51
   0-280-150-788      19.3      202.8      145.9      -      -       -        -
   0-280-150-789      14.35      150.8      108.5      43.5      3      13.59      15.23
   0-280-150-790      18.15      190.8      137.2      43.5      3      17.19      19.26
   0-280-150-791      37.75      396.8      285.4      -      -       -        -
   0-280-150-792      23.3      244.9      176.1      -      -       -        -
   0-280-150-793      10.75      113      81.31      -      -       -        -
   0-280-150-802      25.8      271.2      195      36.25      2.5      26.76      30.00
   0-280-150-802      27      283.8      204.1      43.5      3      25.57      28.66
   0-280-150-803      37.1      389.9      280.5      39.15      2.7      37.03      41.51
   0-280-150-804      32.05      336.8      242.3      43.5      3      30.35      34.02
« Last Edit: March 16, 2010, 09:32:24 AM by sharpxmen »
« Reply #4 on: March 16, 2010, 09:24:42 AM »
   0-280-150-806      32      336.3      241.9      43.5      3      30.30      33.96
   0-280-150-808      31.5      331.1      238.1      55      3.79      26.53      29.73
   0-280-150-810      28.45      299      215.1      -      -      -      -
   0-280-150-811      28.35      298      214.3      50.8      3.5      24.84      27.84
   0-280-150-812      19.3      202.8      145.9      -      -      -      -
   0-280-150-813      28.45      299      215.1      -      -      -      -
   0-280-150-814      36.55      384.1      276.3      43.5      3      34.61      38.79
   0-280-150-818      22.65      238.1      171.2      -      -      -      -
   0-280-150-819      22.65      238.1      171.2      -      -      -      -
   0-280-150-820      22.65      238.1      171.2      -      -      -      -
   0-280-150-821      16.95      178.1      128.1      -      -      -      -
   0-280-150-823      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-150-824      20.75      218.1      156.9      -      -      -      -
   0-280-150-825      18.1      190.2      136.8      43.5      3      17.14      19.21
   0-280-150-826      21.2      222.8      160.3      -      -      -      -
   0-280-150-827      21.2      222.8      160.3      -      -      -      -
   0-280-150-828      22.35      234.9      169      -      -      -      -
   0-280-150-829      19.3      202.8      145.9      -      -      -      -
   0-280-150-830      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-150-831      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-150-834      37.75      396.8      285.4      43.5      3      35.74      40.07
   0-280-150-835      37.75      396.8      285.4      43.5      3      35.74      40.07
   0-280-150-837      150.35      1580      1136      43.5      3      142.36      159.57
   0-280-150-838      150.35      1580      1136      43.5      3      142.36      159.57
   0-280-150-839      152.25      1600      1151      43.5      3      144.16      161.59
   0-280-150-841      59.2      622.2      447.5      -      -      -      -
   0-280-150-842      150.35      1580      1136      43.5      3      142.36      159.57
   0-280-150-845      59.2      622.2      447.5      -      -      -      -
   0-280-150-846      160      1681      1209      -      -      -      -
   0-280-150-846      152.25      1600      1151      43.5      3      144.16      161.59
   0-280-150-901      18.55      195      140.2      43.5      3      17.56      19.69
   0-280-150-902      18.75      197.1      141.7      -      -      -      -
   0-280-150-902      20.75      218.1      156.9      43.5      3      19.65      22.02
   0-280-150-903      18.75      197.1      141.7      -      -      -      -
   0-280-150-905      23.3      244.9      176.1      -      -      -      -
   0-280-150-905      25.1      263.8      189.8      43.5      3      23.77      26.64
   0-280-150-906      23.3      244.9      176.1      -      -      -      -
   0-280-150-908      23.4      245.9      176.9      -      -      -      -
   0-280-150-911      30      315.3      226.8      39.15      2.7      29.94      33.56
   0-280-150-912      30.55      321.1      231      43.5      3      28.93      32.42
   0-280-150-913      24.4      256.4      184.5      39.15      2.7      24.35      27.30
   0-280-150-914      24.4      256.4      184.5      39.15      2.7      24.35      27.30
   0-280-150-917      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-150-921      14.25      149.8      107.7      43.5      3      13.49      15.12
   0-280-150-922      14.25      149.8      107.7      43.5      3      13.49      15.12
   0-280-150-923      29.3      307.9      221.5      -      -      -      -
   0-280-150-924      29.3      307.9      221.5      -      -      -      -
   0-280-150-925      18      189.2      136.1      43.5      3      17.04      19.10
   0-280-150-926      18      189.2      136.1      43.5      3      17.04      19.10
   0-280-150-927      21.8      229.1      164.8      -      -      -      -
   0-280-150-928      21.8      229.1      164.8      -      -      -      -
   0-280-150-929      14.35      150.8      108.5      43.5      3      13.59      15.23
   0-280-150-930      14.35      150.8      108.5      43.5      3      13.59      15.23
   0-280-150-931      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-150-932      28.85      303.2      218.1      -      -      -      -
   0-280-150-933      29      304.8      219.2      -      -      -      -
   0-280-150-934      28.05      294.8      212.1      -      -      -      -
   0-280-150-934      29.3      307.9      221.5      43.5      3      27.74      31.10
   0-280-150-935      16.45      172.9      124.4      -      -      -      -
   0-280-150-936      18.1      190.2      136.8      43.5      3      17.14      19.21
   0-280-150-937      13.5      141.9      102.1      -      -      -      -
   0-280-150-937      14.45      151.9      109.2      43.5      3      13.68      15.34
   0-280-150-938      13.5      141.9      102.1      -      -      -      -
   0-280-150-939      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-150-940      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-150-941      14.1      148.2      106.6      43.5      3      13.35      14.96
   0-280-150-942      14.1      148.2      106.6      43.5      3      13.35      14.96
   0-280-150-943      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-150-944      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-150-945      28.55      300.1      215.8      -      -      -      -
   0-280-150-946      28.55      300.1      215.8      -      -      -      -
   0-280-150-947      24.25      254.9      183.3      39.15      2.7      24.20      27.13
   0-280-150-948      24.25      254.9      183.3      39.15      2.7      24.20      27.13
   0-280-150-951      32.9      345.8      248.7      43.5      3      31.15      34.92
   0-280-150-951      28.55      300.1      215.8      43.5      3      27.03      30.30
   0-280-150-952      25      262.8      189      -      -      -      -
   0-280-150-953      19.5      204.9      147.4      -      -      -      -
   0-280-150-954      17.9      188.1      135.3      -      -      -      -
   0-280-150-955      16.75      176      126.6      -      -      -      -
   0-280-150-955      18.65      196      141      43.5      3      17.66      19.79
   0-280-150-956      16.75      176      126.6      -      -      -      -
   0-280-150-957      21.2      222.8      160.3      -      -      -      -
   0-280-150-958      21.2      222.8      160.3      -      -      -      -
   0-280-150-960      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-150-962      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-150-963      17.7      186      133.8      -      -      -      -
   0-280-150-964      17.7      186      133.8      -      -      -      -
   0-280-150-965      21.05      221.2      159.1      -      -      -      -
   0-280-150-965      22.65      238.1      171.2      43.5      3      21.45      24.04
   0-280-150-966      21.05      221.2      159.1      -      -      -      -
   0-280-150-967      34      357.3      257      43.5      3      32.19      36.09
   0-280-150-968      34      357.3      257      43.5      3      32.19      36.09
   0-280-150-969      42      441.4      317.5      43.5      3      39.77      44.58
   0-280-150-971      22.35      234.9      169      -      -      -      -
   0-280-150-972      21.05      221.2      159.1      -      -      -      -
   0-280-150-973      18.65      196      141      43.5      3      17.66      19.79
   0-280-150-973      19.8      208.1      149.7      43.5      3      18.75      21.01
   0-280-150-974      28.9      303.7      218.5      -      -      -      -
   0-280-150-975      20.15      211.8      152.3      -      -      -      -
   0-280-150-976      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-150-977      18.75      197.1      141.7      43.5      3      17.75      19.90
   0-280-150-978      18.75      197.1      141.7      43.5      3      17.75      19.90
   0-280-150-979      19.8      208.1      149.7      -      -      -      -
   0-280-150-980      19.8      208.1      149.7      -      -      -      -
   0-280-150-981      16.75      176      126.6      -      -      -      -
   0-280-150-982      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-150-983      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-150-984      32.9      345.8      248.7      -      -      -      -
   0-280-150-985      36.65      385.2      277.1      -      -      -      -
   0-280-150-987      14.35      150.8      108.5      -      -      -      -
   0-280-150-988      20.35      213.9      153.8      -      -      -      -
   0-280-150-989      16.75      176      126.6      -      -      -      -
   0-280-150-990      16.75      176      126.6      -      -      -      -
   0-280-150-991      24      252.2      181.4      -      -      -      -
   0-280-150-993      10.5      110.4      79.42      -      -      -      -
   0-280-150-995      10.65      111.9      80.56      -      -      -      -
   0-280-150-996      12.55      131.9      94.92      -      -      -      -
   0-280-150-997      9.6      100.9      72.62      -      -      -      -
   0-280-150-998      21.05      221.2      159.1      -      -      -      -
   0-280-150-999      21.05      221.2      159.1      -      -      -      -
   0-280-155-007      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-155-008      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-155-009      32.95      346.3      249.1      39.15      2.7      32.89      36.86
   0-280-155-010      32.5      341.6      245.7      -      -      -      -
   0-280-155-101      24.35      255.9      184.1      43.5      3      23.06      25.84
   0-280-155-127      39.2      412      296.3      43.5      3      37.12      41.60
   0-280-155-201      18.8      197.6      142.1      -      -      -      -
   0-280-155-203      18.8      197.6      142.1      -      -      -      -
   0-280-155-205      18.8      197.6      142.1      -      -      -      -
   0-280-155-209      18.8      197.6      142.1      -      -      -      -
   0-280-155-213      18.35      192.9      138.7      43.5      3      17.37      19.48
   0-280-155-216      19.85      208.6      150.1      -      -      -      -
   0-280-155-217      18.8      197.6      142.1      -      -      -      -
   0-280-155-219      18.8      197.6      142.1      -      -      -      -
   0-280-155-503      18.2      191.3      137.6      43.5      3      17.23      19.32
   0-280-155-504      24.35      255.9      184.1      43.5      3      23.06      25.84
   0-280-155-505      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-155-600      16.55      173.9      125.1      43.5      3      15.67      17.57
   0-280-155-602      24.3      255.4      183.7      43.5      3      23.01      25.79
   0-280-155-604      13.1      137.7      99.08      -      -      -      -
   0-280-155-606      20.5      215.5      155      43.5      3      19.41      21.76
   0-280-155-607      25      262.8      189      43.5      3      23.67      26.53
   0-280-155-609      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-155-611      24.9      261.7      188.2      43.5      3      23.58      26.43
   0-280-155-613      16.75      176      126.6      43.5      3      15.86      17.78
   0-280-155-700      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-155-702      19      199.7      143.6      43.5      3      17.99      20.17
   0-280-155-703      16.75      176      126.6      43.5      3      15.86      17.78
   0-280-155-705      16.75      176      126.6      43.5      3      15.86      17.78
   0-280-155-706      16.75      176      126.6      43.5      3      15.86      17.78
   0-280-155-707      12.9      135.6      97.57      43.5      3      12.21      13.69
   0-280-155-708      12.9      135.6      97.57      43.5      3      12.21      13.69
   0-280-155-710      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-155-712      19.4      203.9      146.7      43.5      3      18.37      20.59
   0-280-155-715      22.45      235.9      169.7      43.5      3      21.26      23.83
   0-280-155-721      22.4      235.4      169.3      43.5      3      21.21      23.77
   0-280-155-723      21.6      227      163.3      43.5      3      20.45      22.92
   0-280-155-724      21      220.7      158.8      43.5      3      19.88      22.29
   0-280-155-725      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-155-731      9.15      96.21      69.22      43.5      3      8.66      9.71
   0-280-155-734      22.45      235.9      169.7      43.5      3      21.26      23.83
   0-280-155-735      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-155-737      24.85      261.2      187.9      43.5      3      23.53      26.37
   0-280-155-737      34.55      363.1      261.2      43.5      3      32.71      36.67
   0-280-155-739      26.35      276.9      199.2      43.5      3      24.95      27.97
   0-280-155-740      21.1      221.8      159.5      43.5      3      19.98      22.39
   0-280-155-742      15.8      166.1      119.4      43.5      3      14.96      16.77
   0-280-155-744      19      199.7      143.6      43.5      3      17.99      20.17
   0-280-155-746      19      199.7      143.6      43.5      3      17.99      20.17
   0-280-155-748      18.3      192.3      138.3      43.5      3      17.33      19.42
   0-280-155-749      33.3      350      251.7      43.5      3      31.53      35.34
   0-280-155-750      22.45      235.9      169.7      43.5      3      21.26      23.83
   0-280-155-752      28.55      300.1      215.8      -      -      -      -
   0-280-155-753      11.8      124      89.25      43.5      3      11.17      12.52
   0-280-155-756      12.7      133.5      96.06      43.5      3      12.03      13.48
   0-280-155-757      19      199.7      143.6      43.5      3      17.99      20.17
   0-280-155-758      19      199.7      143.6      43.5      3      17.99      20.17
   0-280-155-759      30      315.3      226.8      43.5      3      28.41      31.84
   0-280-155-761      14      147.1      105.8      43.5      3      13.26      14.86
   0-280-155-763      9.1      95.69      68.84      43.5      3      8.62      9.66
   0-280-155-764      9.1      95.69      68.84      43.5      3      8.62      9.66
   0-280-155-765      16.75      176      126.6      43.5      3      15.86      17.78
   0-280-155-766      33.3      350      251.7      43.5      3      31.53      35.34
   0-280-155-769      16.75      176      126.6      43.5      3      15.86      17.78
   0-280-155-770      16.75      176      126.6      43.5      3      15.86      17.78
   0-280-155-773      14      147.1      105.8      43.5      3      13.26      14.86
   0-280-155-774      26      273.3      196.6      43.5      3      24.62      27.59
   0-280-155-777      14.25      149.8      107.7      43.5      3      13.49      15.12
   0-280-155-780      22.3      234.4      168.6      43.5      3      21.12      23.67
   0-280-155-782      21.3      223.9      161      43.5      3      20.17      22.61
   0-280-155-784      21.3      223.9      161      43.5      3      20.17      22.61
   0-280-155-786      9.5      99.89      71.86      43.5      3      9.00      10.08
   0-280-155-787      16.75      176      126.6      43.5      3      15.86      17.78
   0-280-155-788      31      325.8      234.4      43.5      3      29.35      32.90
   0-280-155-789      21      220.7      158.8      43.5      3      19.88      22.29
   0-280-155-791      16.75      176      126.6      43.5      3      15.86      17.78
   0-280-155-793      9.1      95.69      68.84      43.5      3      8.62      9.66
   0-280-155-794      12.6      132.4      95.3      43.5      3      11.93      13.37
   0-280-155-795      11.3      118.8      85.47      43.5      3      10.70      11.99
   0-280-155-798      26.8      281.7      202.6      43.5      3      25.38      28.44
   0-280-155-800      16.75      176      126.6      43.5      3      15.86      17.78
   0-280-155-804      33.3      350      251.7      43.5      3      31.53      35.34
   0-280-155-807      14.25      149.8      107.7      43.5      3      13.49      15.12
   0-280-155-808      14      147.1      105.8      43.5      3      13.26      14.86
   0-280-155-809      16.75      176      126.6      43.5      3      15.86      17.78
   0-280-155-810      14      147.1      105.8      43.5      3      13.26      14.86
   0-280-155-811      34.3      360.5      259.3      43.5      3      32.48      36.40
   0-280-155-812      9.1      95.69      68.84      43.5      3      8.62      9.66
   0-280-155-814      11.5      120.9      86.98      43.5      3      10.89      12.21
   0-280-155-816      14      147.1      105.8      43.5      3      13.26      14.86
   0-280-155-819      16.75      176      126.6      43.5      3      15.86      17.78
   0-280-155-820      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-155-821      14.25      149.8      107.7      43.5      3      13.49      15.12
   0-280-155-822      21      220.7      158.8      43.5      3      19.88      22.29
   0-280-155-823      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-155-824      16.75      176      126.6      43.5      3      15.86      17.78
   0-280-155-825      21.3      223.9      161      43.5      3      20.17      22.61
   0-280-155-828      21.3      223.9      161      43.5      3      20.17      22.61
   0-280-155-830      33.3      350      251.7      43.5      3      31.53      35.34
   0-280-155-831      31.8      334.2      240.4      55.1      3.8      26.75      29.99
   0-280-155-832      22.5      236.5      170.1      43.5      3      21.30      23.88
   0-280-155-835      14      147.1      105.8      43.5      3      13.26      14.86
   0-280-155-837      9.1      95.69      68.84      43.5      3      8.62      9.66
   0-280-155-839      20.7      217.6      156.5      43.5      3      19.60      21.97
   0-280-155-842      14      147.1      105.8      43.5      3      13.26      14.86
   0-280-155-843      11.1      116.7      83.96      43.5      3      10.51      11.78
   0-280-155-844      14.3      150.3      108.1      43.5      3      13.54      15.18
   0-280-155-845      22.3      234.4      168.6      43.5      3      21.12      23.67
   0-280-155-846      12.9      135.6      97.57      43.5      3      12.21      13.69
   0-280-155-847      14      147.1      105.8      43.5      3      13.26      14.86
   0-280-155-848      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-155-857      19.8      208.1      149.7      43.5      3      18.75      21.01
   0-280-155-868      34.5      362.6      260.8      43.5      3      32.67      36.62
   0-280-155-869      25.4      267      192      43.5      3      24.05      26.96
   0-280-155-870      14      147.1      105.8      43.5      3      13.26      14.86
   0-280-155-871      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-155-872      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-155-874      16.75      176      126.6      43.5      3      15.86      17.78
   0-280-155-876      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-155-884      16.75      176      126.6      -      -      -      -
   0-280-155-885      14.1      148.2      106.6      43.5      3      13.35      14.96
   0-280-155-886      11.1      116.7      83.96      43.5      3      10.51      11.78
   0-280-155-887      16.75      176      126.6      43.5      3      15.86      17.78
   0-280-155-890      16.35      171.8      123.6      43.5      3      15.48      17.35
   0-280-155-892      33      346.8      249.5      -      -      -      -
   0-280-155-892      34.7      364.7      262.3      43.5      3      32.86      36.83
   0-280-155-892      35.58      373.9      269      43.5      3      33.69      37.76
   0-280-155-893      36.75      386.2      277.8      43.5      3      34.80      39.00
   0-280-155-894      29.9      314.2      226      43.5      3      28.31      31.73
   0-280-155-895      29.9      314.2      226      43.5      3      28.31      31.73
   0-280-155-897      20.65      217      156.1      43.5      3      19.55      21.92
   0-280-155-897      28.7      301.6      217      43.5      3      27.18      30.46
   0-280-155-899      20.5      215.5      155      43.5      3      19.41      21.76
   0-280-155-900      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-155-905      8.95      94.11      67.71      43.5      3      8.47      9.50
   0-280-155-909      20      210.2      151.2      -      -      -      -
   0-280-155-917      13.55      142.4      102.4      43.5      3      12.83      14.38
   0-280-155-917      19      199.7      143.6      43.5      3      17.99      20.17
   0-280-155-919      9.1      95.69      68.84      43.5      3      8.62      9.66
   0-280-155-921      16.75      176      126.6      -      -      -      -
   0-280-155-927      23.5      247      177.7      43.5      3      22.25      24.94
   0-280-155-931      28.55      300.1      215.8      43.5      3      27.03      30.30
   0-280-155-933      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-155-936      16.75      176      126.6      43.5      3      15.86      17.78
   0-280-155-940      19      199.7      143.6      43.5      3      17.99      20.17
   0-280-155-942      15.1      158.7      114.2      43.5      3      14.30      16.03
   0-280-155-954      28.55      300.1      215.8      43.5      3      27.03      30.30
   0-280-155-956      24.25      254.9      183.3      43.5      3      22.96      25.74
   0-280-155-962      12.7      133.5      96.06      43.5      3      12.03      13.48
   0-280-155-963      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-155-964      9.1      95.69      68.84      43.5      3      8.62      9.66
   0-280-155-965      9.1      95.69      68.84      43.5      3      8.62      9.66
   0-280-155-967      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-155-968      29.5      310      223      43.5      3      27.93      31.31
   0-280-155-969      14.2      149.2      107.4      43.5      3      13.45      15.07
   0-280-155-970      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-155-971      14.2      149.2      107.4      43.5      3      13.45      15.07
   0-280-155-976      19.1      200.7      144.4      43.5      3      18.09      20.27
   0-280-155-978      20.9      219.7      158      43.5      3      19.79      22.18
   0-280-155-981      11      115.6      83.2      43.5      3      10.42      11.67
   0-280-155-983      20.9      219.7      158      43.5      3      19.79      22.18
   0-280-155-985      20.9      219.7      158      43.5      3      19.79      22.18
   0-280-155-988      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-155-993      16.75      176      126.6      43.5      3      15.86      17.78
   0-280-155-994      16.75      176      126.6      43.5      3      15.86      17.78
   0-280-155-995      16.75      176      126.6      43.5      3      15.86      17.78
   0-280-155-997      16.75      176      126.6      43.5      3      15.86      17.78
   0-280-156-001      16.75      176      126.6      43.5      3      15.86      17.78
   0-280-156-002      16.75      176      126.6      43.5      3      15.86      17.78
   0-280-156-003      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-156-005      14.25      149.8      107.7      43.5      3      13.49      15.12
   0-280-156-006      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-156-009      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-156-010      16.75      176      126.6      43.5      3      15.86      17.78
   0-280-156-011      16.75      176      126.6      43.5      3      15.86      17.78
   0-280-156-012      29.5      310      223      43.5      3      27.93      31.31
   0-280-156-012      41      430.9      310      43.5      3      38.82      43.51
   0-280-156-013      16.35      171.8      123.6      43.5      3      15.48      17.35
   0-280-156-016      18.75      197.1      141.7      43.5      3      17.75      19.90
« Last Edit: March 16, 2010, 09:34:20 AM by sharpxmen »
« Reply #5 on: March 16, 2010, 09:26:39 AM »
   0-280-156-018      16.75      176      126.6      43.5      3      15.86      17.78
   0-280-156-019      16.75      176      126.6      43.5      3      15.86      17.78
   0-280-156-021      29      304.8      219.2      43.5      3      27.46      30.78
   0-280-156-022      25.9      272.2      195.8      -      -      -      -
   0-280-156-023      35.5      373.1      268.4      43.5      3      33.61      37.68
   0-280-156-024      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-156-025      9.1      95.69      68.84      43.5      3      8.62      9.66
   0-280-156-026      28.8      302.7      217.7      43.5      3      27.27      30.57
   0-280-156-027      12.7      133.5      96.06      43.5      3      12.03      13.48
   0-280-156-028      22.8      239.6      172.4      43.5      3      21.59      24.20
   0-280-156-034      14      147.1      105.8      -      -      -      -
   0-280-156-036      18.1      190.2      136.8      43.5      3      17.14      19.21
   0-280-156-038      21.35      224.4      161.4      43.5      3      20.22      22.66
   0-280-156-039      16.75      176      126.6      43.5      3      15.86      17.78
   0-280-156-040      28.8      302.7      217.7      43.5      3      27.27      30.57
   0-280-156-045      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-156-050      12.8      134.5      96.81      43.5      3      12.12      13.59
   0-280-156-052      23.5      247      177.7      43.5      3      22.25      24.94
   0-280-156-053      22.75      239.1      172      43.5      3      21.54      24.15
   0-280-156-057      16.75      176      126.6      43.5      3      15.86      17.78
   0-280-156-058      7.15      75.19      54.1      43.5      3      6.77      7.59
   0-280-156-059      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-156-061      30.15      316.9      227.9      43.5      3      28.55      32.00
   0-280-156-063      33      346.8      249.5      -      -      -      -
   0-280-156-065      26.85      282.2      203      43.5      3      25.42      28.50
   0-280-156-070      26.85      282.2      203      43.5      3      25.42      28.50
   0-280-156-072      37.7      396.2      285      43.5      3      35.70      40.01
   0-280-156-074      27      283.8      204.1      43.5      3      25.57      28.66
   0-280-156-080      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-156-081      24.75      260.1      187.1      43.5      3      23.43      26.27
   0-280-156-083      14.25      149.8      107.7      43.5      3      13.49      15.12
   0-280-156-084      14.25      149.8      107.7      43.5      3      13.49      15.12
   0-280-156-094      16.75      176      126.6      43.5      3      15.86      17.78
   0-280-156-103      16.75      176      126.6      43.5      3      15.86      17.78
   0-280-156-104      16.75      176      126.6      43.5      3      15.86      17.78
   0-280-156-105      16.75      176      126.6      43.5      3      15.86      17.78
   0-280-156-108      16.25      170.8      122.8      43.5      3      15.39      17.25
   0-280-156-123      20.25      212.8      153.1      43.5      3      19.17      21.49
   0-280-156-127      41.5      436.2      313.7      43.5      3      39.29      44.05
   0-280-156-186      20.25      212.8      153.1      43.5      3      19.17      21.49
   0-280-156-208      18.25      191.8      138      43.5      3      17.28      19.37
   0-280-156-937      19.8      208.1      149.7      43.5      3      18.75      21.01
   0-280-158-085      40      420.4      302.4      43.5      3      37.87      42.45
   0-280-159-731      9.15      96.21      69.22      43.5      3      8.66      9.71
   0-280-159-732      9.15      96.21      69.22      43.5      3      8.66      9.71
   B-280-214-912      175      1839      1323      45      3.1      162.92      182.61
   B-280-214-913      175      1839      1323      45      3.1      162.92      182.61
   B-280-410-144      41.25      433.5      311.8      43.5      3      39.06      43.78
   B-280-410-153      57      599.1      430.9      36.25      2.5      59.12      66.27
   B-280-410-153      76      798.8      574.6      72.5      5      55.74      62.48
   B-280-410-475      77.35      812.9      584.8      43.5      3      73.24      82.09
   B-280-412-911      76      798.8      574.6      36.25      2.5      78.83      88.36
   B-280-412-911      106.45      1118      804.7      72.5      5      78.07      87.51
   B-280-431-126      24.85      261.2      187.9      43.5      3      23.53      26.37
   B-280-431-126      34.55      363.1      261.2      43.5      3      32.71      36.67
   B-280-431-127      24.85      261.2      187.9      43.5      3      23.53      26.37
   B-280-431-127      34.55      363.1      261.2      43.5      3      32.71      36.67
   B-280-431-128      34.65      364.2      261.9      43.5      3      32.81      36.78
   B-280-431-128      48.2      506.6      364.4      43.5      3      45.64      51.16
   B-280-431-129      34.65      364.2      261.9      43.5      3      32.81      36.78
   B-280-431-129      48.2      506.6      364.4      43.5      3      45.64      51.16
   B-280-431-130      46.92      493.1      354.7      43.5      3      44.43      49.80
   B-280-431-130      65.23      685.6      493.1      43.5      3      61.76      69.23
   B-280-431-131      46.92      493.1      354.7      43.5      3      44.43      49.80
   B-280-432-115      20.65      217      156.1      43.5      3      19.55      21.92
   B-280-434-499 /1      62.2      653.7      470.2      43.5      3      58.89      66.02
   B-280-434-499 01      87.04      914.8      658      43.5      3      82.42      92.38
   B-280-434-499 02      87.04      914.8      658      43.5      3      82.42      92.38
   B-280-436-038 /1      47.9      503.4      362.1      43.5      3      45.35      50.84
   B-280-436-038 01      66.6      700      503.5      43.5      3      63.06      70.69
   B-280-436-038 /2      47.9      503.4      362.1      43.5      3      45.35      50.84
   B-280-436-038 02      66.6      700      503.5      43.5      3      63.06      70.69
   B-280-436-038 /3      36.85      387.3      278.6      43.5      3      34.89      39.11
   B-280-436-038 /4      36.85      387.3      278.6      43.5      3      34.89      39.11
   B-280-436-038 05      51.23      538.4      387.3      43.5      3      48.51      54.37
   B-280-436-038 06      51.23      538.4      387.3      43.5      3      48.51      54.37
   Motor Craft      LBS/HR      CC/MIN      GRAMS      PSI      BAR      -      -
   D5B      19      199.7      143.6      -      -      -      -
   F78E      19      199.7      143.6      -      -      -      -
   F5DE      24      252.2      181.4      -      -      -      -
   F65E      21      220.7      158.8      -      -      -      -
   F6VE      19      199.7      143.6      43.5      3      17.99      20.17
   FOTE-D9B      22      231.2      166.3      -      -      -      -
   FV6E-EV6      19      199.7      143.6      -      -      -      -
   XF1E      21      220.7      158.8      -      -      -      -
   XR3E      24      252.2      181.4      -      -      -      -
   Chrysler      LBS/HR      CC/MIN      GRAMS      PSI      BAR      -      -
   04854181 Blue      22.5      236.5      170.1      49      3.38      20.07      22.50
   33007127 Brown      21      220.7      158.8      39      2.69      21.00      23.54
   4275312      27      283.8      204.1      55      3.79      22.74      25.48
   4306018      32      336.3      241.9      55      3.79      26.95      30.20
   4306024      27      283.8      204.1      55      3.79      22.74      25.48
   4418213      33.25      349.5      251.4      55      3.79      28.00      31.38
   4418258      33.25      349.5      251.4      55      3.79      28.00      31.38
   4418474      27      283.8      204.1      55      3.79      22.74      25.48
   4418475      27      283.8      204.1      55      3.79      22.74      25.48
   4504322      33      346.8      249.5      55      3.79      27.79      31.15
   4532586      52      546.5      393.1      55      3.79      43.79      49.08
   4612175      24      252.2      181.4      50      3.45      21.20      23.76
   5277895      34      357.3      257      55      3.79      28.63      32.09
   53003956 Dark Tan      21      220.7      158.8      39      2.69      21.00      23.54
   53030262      24.6      258.5      186      39      2.69      24.60      27.57
   53030343 Tan      21      220.7      158.8      39      2.69      21.00      23.54
   53030778 Grey      23.2      243.8      175.4      49      3.38      20.70      23.20
   P4452204      35      367.9      264.6      55      3.79      29.47      33.04
   P4452803      30      315.3      226.8      55      3.79      25.26      28.32
   P4452804      36      378.4      272.2      55      3.79      30.31      33.98
   P4529495      42      441.4      317.5      55      3.79      35.37      39.64
   P5249452      52      546.5      393.1      55      3.79      43.79      49.08
   EOSE-      46.1      484.5      348.5      33.35      2.3      49.85      55.88
   E3EE-9F593AA      14      147.1      105.8      -      -      -      -
   E3EE-9F593AB      14      147.1      105.8      30      2.07      15.96      17.89
   E3EE-9F593BA      14      147.1      105.8      -      -      -      -
   E3ZE-9F593AA      30      315.3      226.8      37      2.55      30.80      34.52
   E3ZE-9F593BA      30      315.3      226.8      37      2.55      30.80      34.52
   E3ZE-9F593B1A      30      315.3      226.8      37      2.55      30.80      34.52
   E43E-9F593AC      55.5      583.3      419.6      -      -      -      -
   E4EE-9F593AA      14      147.1      105.8      -      -      -      -
   E4EX-9F593A1A      23      241.7      173.9      -      -      -      -
   E4EX-9F593AA      23.7      249.1      179.2      -      -      -      -
   E4ZE-      52.4      550.7      396.1      32      2.21      57.85      64.84
   E4ZE-AA      30      315.3      226.8      37      2.55      30.80      34.52
   E4ZE-A1A      30      315.3      226.8      37      2.55      30.80      34.52
   E4ZE-A2A      30      315.3      226.8      37      2.55      30.80      34.52
   E4ZE-A3A      30      315.3      226.8      37      2.55      30.80      34.52
   E4ZE-B1A      30      315.3      226.8      37      2.55      30.80      34.52
   E59E-9F593AA      14      147.1      105.8      30.45      2.1      15.84      17.76
   E59E-9F593AB      14      147.1      105.8      30.45      2.1      15.84      17.76
   E59E-9F593A1A      14      147.1      105.8      30.45      2.1      15.84      17.76
   E59E-9F593A2A      14      147.1      105.8      30.45      2.1      15.84      17.76
   E59E-9F593A3A      14      147.1      105.8      30.45      2.1      15.84      17.76
   E59E-9F593A2B      14      147.1      105.8      30.45      2.1      15.84      17.76
   E5TE-      19      199.7      143.6      33.35      2.3      20.55      23.03
   E5ZE-9F593AA      35      367.9      264.6      37      2.55      35.93      40.28
   E5ZE-9F593AB      35      367.9      264.6      37      2.55      35.93      40.28
   E5ZE-9F593A1A      35      367.9      264.6      37      2.55      35.93      40.28
   E5ZE-9F593A2A      35      367.9      264.6      37      2.55      35.93      40.28
   E5ZE-9F593A3A      35      367.9      264.6      37      2.55      35.93      40.28
   E5ZE-9F593A2B      35      367.9      264.6      37      2.55      35.93      40.28
   E6EE-9F593AB      19      199.7      143.6      40      2.76      18.76      21.03
   E6EE-9F593A3B      19      199.7      143.6      40      2.76      18.76      21.03
   E6EE-9F593A2A      19      199.7      143.6      40      2.76      18.76      21.03
   E6EE-9F593A3A      19      199.7      143.6      40      2.76      18.76      21.03
   E6EE-9F593A1B      19      199.7      143.6      40      2.76      18.76      21.03
   E6EE-9F593A2B      19      199.7      143.6      40      2.76      18.76      21.03
   E6TE-9F593AB      19      199.7      143.6      32      2.21      20.98      23.51
   E6TE-9F593A1B      19      199.7      143.6      32      2.21      20.98      23.51
   E6TE-9F593BB      19      199.7      143.6      32      2.21      20.98      23.51
   E6TE-A1B      19      199.7      143.6      32      2.21      20.98      23.51
   E6TE-A2B      19      199.7      143.6      32      2.21      20.98      23.51
   E6TE-A2B      18.5      194.4      139.9      43.5      3      17.52      19.63
   E6TE-A3B      19      199.7      143.6      32      2.21      20.98      23.51
   E6TE-A3B      18.5      194.4      139.9      43.5      3      17.52      19.63
   E67C-9F593AB      14      147.1      105.8      33.35      2.3      15.14      16.97
   E67E-9F593BB      14      147.1      105.8      33.35      2.3      15.14      16.97
   E67E-B1A      14      147.1      105.8      33.35      2.3      15.14      16.97
   E67E-B1B      14      147.1      105.8      33.35      2.3      15.14      16.97
   E67E-B4B      14      147.1      105.8      33.35      2.3      15.14      16.97
   E67E-B4B      13.4      140.8      101.3      43.5      3      12.69      14.22
   E7TE-      23      241.7      173.9      43      2.96      21.90      24.55
   E8TE-      23      241.7      173.9      43      2.96      21.90      24.55
   E9SE-      30      315.3      226.8      43.5      3      28.41      31.84
   F0SE-B5A      14.45      151.9      109.2      43.5      3      13.68      15.34
   F0TE-9F593B1A      19      199.7      143.6      -      -      -      -
   F0TE-C3A      19.75      207.6      149.3      43.5      3      18.70      20.96
   F0TE-9F593D1A      19      199.7      143.6      -      -      -      -
   F0TE-9F593D5A      18.25      191.8      138      43.5      3      17.28      19.37
   F0TE-D5B      20      210.2      151.2      43.5      3      18.94      21.23
   F1SE-      31      325.8      234.4      43.5      3      29.35      32.90
   F1SE-E1A      30      315.3      226.8      43.5      3      28.41      31.84
   F1TE-D5A      24.25      254.9      183.3      39.15      2.7      24.20      27.13
   F1TZ-      24      252.2      181.4      43.5      3      22.72      25.47
   F1ZE-B4C      14      147.1      105.8      -      -      -      -
   F2LE-      24      252.2      181.4      -      -      -      -
   F2LE-9F593-B2A      24      252.2      181.4      -      -      -      -
   F3DE-9F593A2B      25      262.8      189      -      -      -      -
   F47E-9F593A2D      13.7      144      103.6      43.5      3      12.97      14.54
   XL5E-A2A      19.1      200.7      144.4      43.5      3      18.09      20.27
   XL5E-B2A      19.1      200.7      144.4      43.5      3      18.09      20.27
   Tomco      LBS/HR      CC/MIN      GRAMS      PSI      BAR      -      -
   5720A520      17.9      188.1      135.3      43.5      3      16.95      19.00
   5720D570      17.9      188.1      135.3      43.5      3      16.95      19.00
   5720D780      17.9      188.1      135.3      43.5      3      16.95      19.00
   5720D810      17.9      188.1      135.3      43.5      3      16.95      19.00
   Nippon Denso      LBS/HR      CC/MIN      GRAMS      PSI      BAR      -      -
   195500-0900 Orange      64.7      680      489.1      -      -      -      -
   195500-1350 Red      43.77      460      330.9      -      -      -      -
   195500-1350 Purple      43.77      460      330.9      -      -      -      -
   195500-1370 Tan      52.33      550      395.6      -      -      -      -
   195500-1370 Purple      52.33      550      395.6      -      -      -      -
   195500-1650      28.55      300.1      215.8      37      2.55      29.31      32.86
   195500-1970 Navy Blue      19.5      204.9      147.4      37      2.55      20.02      22.44
   195500-2010 Red      43.77      460      330.9      -      -      -      -
   195500-2020 Purple      52.33      550      395.6      -      -      -      -
   195500-2110 Purple      11.4      119.8      86.23      37      2.55      11.70      13.12
   Light Green      13.8      145      104.3      37      2.55      14.17      15.88
   Dark Blue      13.8      145      104.3      -      -      -      -
   Gray      13.8      145      104.3      -      30      -      -
   Red / Dark Blue      14.75      155      111.5      42      2.9      14.21      15.93
   Violet      14.75      155      111.5      42      2.9      14.21      15.93
   Sky Blue      14.75      155      111.5      42      2.9      14.21      15.93
   Light Green      16.75      176      126.6      42      2.9      16.14      18.09
   Grey      16.75      176      126.6      42      2.9      16.14      18.09
   Dark Grey      17.3      181.8      130.8      37      2.55      17.76      19.91
   Dark Grey      19      199.7      143.6      42      2.9      18.31      20.52
   Beige      19      199.7      143.6      42      2.9      18.31      20.52
   Orange      19      199.7      143.6      42      2.9      18.31      20.52
   Brown      19      199.7      143.6      42      2.9      18.31      20.52
   Pink      19      199.7      143.6      42      2.9      18.31      20.52
   Dark Blue      19      199.7      143.6      42      2.9      18.31      20.52
   Orange / Blue      19      199.7      143.6      42      2.9      18.31      20.52
   Red      19      199.7      143.6      42      2.9      18.31      20.52
   Blue      20      210.2      151.2      37      2.55      20.53      23.02
   Sky Blue      20.3      213.4      153.5      42      2.9      19.56      21.93
   Beige      20.25      212.8      153.1      42      2.9      19.51      21.87
   Yellow      20.25      212.8      153.1      42      2.9      19.51      21.87
   Yellow / Orange      23.8      250.1      179.9      42      2.9      22.93      25.71
   Green      23.8      250.1      179.9      42      2.9      22.93      25.71
   Violet      23.8      250.1      179.9      42      2.9      22.93      25.71
   Brown      23.8      250.1      179.9      42      2.9      22.93      25.71
   Light Green      26.85      282.2      203      42      2.9      25.87      29.00
   Violet      26.85      282.2      203      42      2.9      25.87      29.00
   Yellow      28.05      294.8      212.1      37      2.55      28.80      32.28
   Pink      28.05      294.8      212.1      37      2.55      28.80      32.28
   Green      28.05      294.8      212.1      37      2.55      28.80      32.28
   Pink      30      315.3      226.8      42      2.9      28.91      32.40
   Light Green      30      315.3      226.8      42      2.9      28.91      32.40
   Red / Orange      34.75      365.2      262.7      37      2.55      35.68      39.99
   Black      40.9      429.9      309.2      37      2.55      41.99      47.07
   Nissan / Infiniti      LBS/HR      CC/MIN      GRAMS      PSI      BAR      -      -
   16600-40P07      31.9      335.3      241.2      -      -      -      -
   16600-40P08      31.9      335.3      241.2      -      -      -      -
   16600-53J00      21.7      228.1      164      -      -      -      -
   16603-P9000      25      262.8      189      -      -      -      -
   16603-P9010      25      262.8      189      -      -      -      -
   16603-02P00      25      262.8      189      -      -      -      -
   16603-02P10      25      262.8      189      -      -      -      -
   GM      LBS/HR      CC/MIN      GRAMS      PSI      BAR      -      -
   5235027      18.65      196      141      43.5      3      17.66      19.79
   5235041      27.8      292.2      210.2      43.5      3      26.32      29.51
   5235047      19.3      202.8      145.9      43.5      3      18.27      20.48
   5235136      15.2      159.8      114.9      46      3.17      14.00      15.69
   5235210      14.65      154      110.8      43.5      3      13.87      15.55
   5235211      21.6      227      163.3      43.5      3      20.45      22.92
   5235236      32.25      338.9      243.8      -      -      -      -
   5235301      20.5      215.5      155      -      -      -      -
   5235302      20.5      215.5      155      -      -      -      -
   5235302      21.6      227      163.3      43.5      3      20.45      22.92
   5235357      21.7      228.1      164      43.5      3      20.55      23.03
   5235366      21.7      228.1      164      43.5      3      20.55      23.03
   5235434      20.5      215.5      155      -      -      -      -
   5235435      20.5      215.5      155      -      -      -      -
   5235436      20.5      215.5      155      43.5      3      19.41      21.76
   5235437      20.5      215.5      155      -      -      -      -
   5235451      21.7      228.1      164      43.5      3      20.55      23.03
   12456154      26.2      275.4      198.1      -      -      -      -
   12482704      28.6      300.6      216.2      -      -      -      -
   12555894      26      273.3      196.6      -      -      -      -
   15637677      32      336.3      241.9      45      3.1      29.79      33.39
   17069647      21.7      228.1      164      43.5      3      20.55      23.03
   17069648      21.7      228.1      164      43.5      3      20.55      23.03
   17084888      15.4      161.9      116.4      43.5      3      14.58      16.34
   17086517      17.6      185      133.1      43.5      3      16.66      18.68
   17086542      19.6      206      148.2      43.5      3      18.56      20.80
   17086544      22.45      235.9      169.7      43.5      3      21.26      23.83
   17087325      20      210.2      151.2      50      3.45      17.66      19.80
   17089116      30.8      323.7      232.8      43.5      3      29.16      32.69
   17089569      15.4      161.9      116.4      43.5      3      14.58      16.34
   17090844      29.7      312.1      224.5      -      -      -      -
   17091189      23.8      250.1      179.9      43.5      3      22.54      25.26
   17091728      19.2      201.8      145.1      43.5      3      18.18      20.38
   17095004      24.75      260.1      187.1      43.5      3      23.43      26.27
   17100262      16.65      175      125.9      43.5      3      15.77      17.67
   17102727      27.8      292.2      210.2      43.5      3      26.32      29.51
   17103001      19.6      206      148.2      43.5      3      18.56      20.80
   17103007      17.7      186      133.8      43.5      3      16.76      18.79
   17103146      21.2      222.8      160.3      -      -      -      -
   17103146      19.4      203.9      146.7      43.5      3      18.37      20.59
   17104487      50      525.5      378      43.5      3      47.34      53.07
   17104959      95      998.5      718.2      43.5      3      89.95      100.83
   17104988      72      756.7      544.3      43.5      3      68.17      76.42
   17106121      18.1      190.2      136.8      43.5      3      17.14      19.21
   17106488      18.1      190.2      136.8      43.5      3      17.14      19.21
   17109488      16.95      178.1      128.1      43.5      3      16.05      17.99
   17109596      19.4      203.9      146.7      43.5      3      18.37      20.59
   17109826      18.15      190.8      137.2      43.5      3      17.19      19.26
   17109952      21.7      228.1      164      43.5      3      20.55      23.03
   17109953      21.7      228.1      164      43.5      3      20.55      23.03
   17113738      50      525.5      378      43.5      3      47.34      53.07
   17113741      55      578.1      415.8      43.5      3      52.08      58.37
   17113742      75      788.3      567      43.5      3      71.01      79.60
   17113743      85      893.4      642.6      43.5      3      80.48      90.21
   17113744      96      1009      725.7      43.5      3      90.90      101.89
   17113812      30      315.3      226.8      43.5      3      28.41      31.84
   17113813      42      441.4      317.5      43.5      3      39.77      44.58
   17113814      65      683.2      491.4      43.5      3      61.55      68.99
   17120254      20.85      219.1      157.6      50      3.45      18.41      20.64
   17120683      18      189.2      136.1      43.5      3      17.04      19.10
   17121068      20.85      219.1      157.6      50      3.45      18.41      20.64
   17121882      29.7      312.1      224.5      -      -      -      -
   17121909      26.6      279.6      201.1      50      3.45      23.49      26.33
   17121947      20      210.2      151.2      50      3.45      17.66      19.80
   17121948      20      210.2      151.2      50      3.45      17.66      19.80
   17122683      24      252.2      181.4      43.5      3      22.72      25.47
   17124068      25.1      263.8      189.8      43.5      3      23.77      26.64
   17124248      23.9      251.2      180.7      43.5      3      22.63      25.37
   17124251      26.6      279.6      201.1      43.5      3      25.19      28.23
   17124289      26.6      279.6      201.1      50      3.45      23.49      26.33
   17191728      19.5      204.9      147.4      43.5      3      18.46      20.70
   23424745      78      819.8      589.7      43.5      3      73.86      82.78
   25176913      13.8      145      104.3      43.5      3      13.07      14.65
   25180245      23.8      250.1      179.9      43.5      3      22.54      25.26
   25317628      22.1      232.3      167.1      43.5      3      20.93      23.46
   25324367      65      683.2      491.4      43.5      3      61.55      68.99
   25324343      42      441.4      317.5      43.5      3      39.77      44.58
   25324344      55      578.1      415.8      43.5      3      52.08      58.37
   25324366      30      315.3      226.8      43.5      3      28.41      31.84
   25324743      42      441.4      317.5      43.5      3      39.77      44.58
   25324746      85      893.4      642.6      43.5      3      80.48      90.21
   23250-11040      14.75      155      111.5      41.2      2.84      14.35      16.09
   23250-13010      14.9      156.6      112.6      -      -      -      -
   23250-16061      34.7      364.7      262.3      36.25      2.5      35.99      40.34
   23250-16080      20.5      215.5      155      41.2      2.84      19.95      22.36
   23250-16120      16.75      176      126.6      41.2      2.84      16.30      18.27
   23250-35010      23.75      249.6      179.5      36.25      2.5      24.63      27.61
   23250-35020      27      283.8      204.1      36.25      2.5      28.01      31.39
   23250-35040      19      199.7      143.6      41.2      2.84      18.49      20.72
   23250-42010      40.85      429.3      308.8      36.25      2.5      42.37      47.49
   23250-45011      16.9      177.6      127.8      36.25      2.5      17.53      19.65
   23250-49035      50.4      529.7      381      36.25      2.5      52.28      58.60
   23250-61010      20.5      215.5      155      41.2      2.84      19.95      22.36
   23250-62010      20.5      215.5      155      41.2      2.84      19.95      22.36
   23250-62020      19      199.7      143.6      41.2      2.84      18.49      20.72
   23250-62030      19      199.7      143.6      41.2      2.84      18.49      20.72
   23250-70080      29.95      314.8      226.4      41.2      2.84      29.14      32.66
   23250-73010      19      199.7      143.6      41.2      2.84      18.49      20.72
   23250-74030      19      199.7      143.6      41.2      2.84      18.49      20.72
   23250-74040      27.55      289.6      208.3      36.25      2.5      28.58      32.03
   23250-74050      23.75      249.6      179.5      36.25      2.5      24.63      27.61
   23250-74060      19      199.7      143.6      41.2      2.84      18.49      20.72
   23250-74090      41.85      439.8      316.4      36.25      2.5      43.41      48.66
   23250-79015      40.85      429.3      308.8      36.25      2.5      42.37      47.49
   23250-79045      27      283.8      204.1      41.2      2.84      26.27      29.45
« Last Edit: March 16, 2010, 09:36:22 AM by sharpxmen »
Complete Loser
« Reply #6 on: March 16, 2010, 09:31:13 AM »
 :clap:
Outstanding! :)
I have some 155-700's out of a v10. Wanted to see their specs.
Thanks again. That was fast!
« Reply #7 on: March 16, 2010, 09:41:25 AM »
:clap:
Outstanding! :)
no problem, took more to format it for the forum than to calculate
you can make your own excel calculator just use this formula for 39 psi =<old_flow_cell>*SQRT(39/<old_fuel_pressure_cell>)
