Author Topic: Another lift question  (Read 1941 times)
longhorn
« on: May 15, 2010, 03:23:20 PM »
I was just wondering how big of a tire I can fit under my jeep if I cut the front fenders off even with the hood and took the rear fender flares off.
 :beers:
longhorn
Re: Another lift question
« Reply #1 on: May 15, 2010, 03:28:39 PM »
I forgot to add that I would add a 1.25in body lift or maybe a 2-3in spacer lift
« Reply #2 on: May 15, 2010, 05:59:35 PM »
i'm guessing 35'' tires
« Reply #3 on: May 16, 2010, 09:06:18 AM »
33-35's depending if you mind if it rubs a little
TrailsLessTaken
« Reply #4 on: May 18, 2010, 08:05:35 AM »
I would think you could do 33's, you might need to cut the rear wheel wells out a lil bigger so that way it doesnt rub
andrew383
« Reply #5 on: May 27, 2010, 08:44:09 PM »
On highline kits you can do 35's with no lift and 37's with 2.5" lift...Soooo fender delete is say 35's
