Author Topic: shifting too soon  (Read 3450 times)
aerotech
Re: shifting too soon
« Reply #15 on: June 09, 2010, 12:13:54 PM »
I have the same tire size and gearing. I also have absolutely no power. If it is windy top speed is about 50. Did you also replace the TB with 4.0 TB?? Has it helped with power issues??
jonesy
« Reply #16 on: June 09, 2010, 06:50:55 PM »
My top speed with a head wind is also 50-55. I do have a 4.0TB, but I havent put it on yet.Just trying 1 thing at a time to see what the difference is. I did grind out the intake bigger before I installed the TB spacer.
Offline bootguy
« Reply #17 on: June 18, 2010, 09:23:48 PM »
That is enough tire to change the shift point on the automatic transmission. You need to change the speedo gears for correct shifting.
