Author Topic: Air inlet tube  (Read 1297 times)
  • Poseur ExtraordinaireŽ
Air inlet tube
« on: June 27, 2010, 10:24:16 AM »
Any advice on removing the air inlet tube on top of the engine block?
I have a new one to replace the old one and not sure if I have toremove the rubber gasket as well as the tube itself.
Re: Air inlet tube
« Reply #1 on: June 27, 2010, 03:13:01 PM »
ow can something so hard to get out be so easy to put in.....
Practically destroyed the part, but new one is in and Jeep is running better than ever. :thumbsup:
Re: Air inlet tube
« Reply #2 on: June 27, 2010, 03:15:21 PM »
...also...took the throttle body off for the first time.  Was having a stalling issue when stopped or sometimes when pushing in the clutch to make a turn at slower speeds.
Cleaned out the whole throttle body as well as the IAC....seemed to do the trick!   :thumbsup:
