Author Topic: Time for an SYE  (Read 4208 times)
N8whitie
Re: Time for an SYE
« Reply #15 on: September 22, 2010, 09:30:16 AM »
Good point on the power going thru the drivetrain will change the pinion angle.
N8 if your kit comes with a T-case drop down use it. That helps get the geometry close enough so you don't need to worry about it.
 Yeah, the kit does come with it. I have to get under my rig and see what it has. I haven't really had enough downtime to check it out. Looks like I'll be home this week or next week so I have to take the skid plate off and do some research. I feel like a tool not knowing whats under my rig. ha.
snb73
Re: Time for an SYE
« Reply #16 on: September 24, 2010, 09:18:16 AM »
A SYE is very easy to install. I was a bit gun shy about the unknown, but once I was done I realized how simple it was. I used a Currie Enterprizes one. Any of the name brand ones should be fine. Rugged Ridge is a bit entry level. JB has some nice stuff.
It took more time cleaning the cases than it did actually installing the SYE.
 http://www.jbconversions.com/products/sye/np231j_short_sye.php
