Author Topic: 92 YJ Strip Down  (Read 8544 times)
0 Members and 4 Guests are viewing this topic.
Re: 92 YJ Strip Down
« Reply #30 on: October 23, 2010, 07:26:53 PM »
Another queston: How do I tell if the ball joints on the front steering need replacing??? I am having to take apart and replace the rubbers that hold the grease in.
you can usually tell if you move the steering left/right to see if there is play. you can also lift the front axle on each side (jack under the axle tube and lift just enough so the tire is off the ground) and grab on the tire and move left right so you can feel if there's play in the joints. You'll need someone to spot.
littledavid123
« Reply #31 on: November 23, 2010, 03:08:10 PM »
Been off the project for a while, my 12 yr old daughter broke her arm and leg playing basketball.    :gimp:
Will the gas sending unit from the original 2.5  work when I switch out to a
4.3 L Vortec?
