Author Topic: Auto darkening welding hood  (Read 4576 times)
« on: October 04, 2010, 09:03:02 PM »
What hoods are you guy's using? I am looking to upgrade my hood. I have a plain Jane Jackson. It has no settings or adjustments that can be made. It's also a solar cell powered one. I am looking for one that has a battery and solar cell, or battery only.
Re: Auto darkening welding hood
« Reply #1 on: October 04, 2010, 10:01:50 PM »
i'm using a $30 chinese one off ebay, it has both darkness and sensitivity adjustments on the outside (which is nice). It's a bit finicky on the sensitivity adj, i had sometimes issues with it flickering (and that's no good since you can't see afterwards) and i don't know if it's b/c it's solar powered or b/c it's crappy (or maybe both) - i got it adjusted once and it worked and i didn't touch the sensitivity ever since (been working knock on wood so i don't play with that button anymore). If you weld a lot i'd say go for a name brand, otherwise one of these would do the job ok but not for a pro welder for sure.
« Reply #2 on: October 06, 2010, 09:19:24 AM »
Only spend as much as your eyes are worth........
I don't skimp here....
« Reply #3 on: October 06, 2010, 10:34:24 AM »
I think along those same lines.
« Reply #4 on: October 13, 2010, 07:21:22 PM »
Looking at various hoods. I am wondering about the darkening speed. They vary from 1-3600 to 1-25000 of a second to darken. Do you think you would notice the difference between the slower one and a faster one? I mean it's a fraction of a second reguardless. Or is this more a marketing ploy?
« Reply #5 on: October 13, 2010, 08:39:20 PM »
you notice but is not that big of a deal, the high end ones are better though, you can tell on mine when it kicks in, on a friend's Miller you can't as it's way faster.
« Reply #6 on: October 13, 2010, 08:46:19 PM »
i switched back to using the old fashion masks rather than the auto dimmers because they are to slow or not dark enough and my eyes start to "hurt" after extended use.  :wall:... higher end ones would probably be better than the ones i have used.
« Reply #7 on: October 13, 2010, 08:59:04 PM »
With the welding I do mostly is very small spot welds and short beads. I am looking at a Jackson hood. I like everything about it but the darkening speed. It was not listed on the specs so I called them. It's pretty slow at 1-2750. I thought I miss heard him, but that's what he said. I was also looking at a Lincoln. Pretty nice hood to but it has 2 sensors VS. the 3 of the Jackson. About the same price.
My currant hood is a Jackson. It's pretty out dated. Fixed 11 shade with no adjustments.
I have a tip and flip hood too. It has a #13 gold filter. I went thru welding school with it. I would use it but I need to see when I do those small spot welds.
« Reply #8 on: October 13, 2010, 10:37:34 PM »
I use a 250 Watt halogen light on the work area then you can see through the lens...
« Reply #9 on: October 14, 2010, 11:12:47 PM »
I have a Harbor Frieght auto dimming unit.  It says it's super fast, but I see a flash before it's dark.  I just squint for a second and it's all good.  : )
« Reply #10 on: October 15, 2010, 08:42:22 PM »
  I think my eyes are worth more than $50.00. I am looking at another Jackson hood.
ZanderJay
« Reply #11 on: October 20, 2010, 07:05:41 AM »
I've use an adjustable shade, which is might be good in solar. It was a kind of helmet that can put you into a serious work. This is safe and productivity helmet.
« Reply #12 on: October 20, 2010, 02:03:25 PM »
http://www.lincolnelectric.com/products/viking-welding-helmets.asp
I went with model K2815-1. So far I love it!! Much improvement over my older Jackson!
« Reply #13 on: October 25, 2010, 03:35:55 PM »
I've had a Hobart Hood for about 5 years, and have been happy with how it works.  Paid about $100 for it on sale.  I've used fancier helmets and never noticed a difference, Also use a really cheap HF hood that a friend had and got some pretty good headaches from it.
This is the same one I've got
http://store.cyberweld.com/hohowehehoth.html?utm_medium=shoppingengine&utm_source=googlebase
« Last Edit: October 25, 2010, 03:38:22 PM by oldjeep »
« Reply #14 on: October 25, 2010, 03:37:15 PM »
Glad to hear you got a good one.
