Author Topic: Any opinions on GL-4?  (Read 2855 times)
« on: October 07, 2010, 08:53:41 PM »
Plan on running this GL-4 gear oil in my AX-5 (95 YJ), any comments?  Would there be any issues in a open-diff axle (D35)?
Thanks for your time.
http://www.crcindustries.com/ei/content/prod_detail.aspx?PN=SL24239&S=C
Quote
Product Description
GL-4 Hypoid Gear Oil has low pour points and high temp properties to provide lubrication over a wide temperature range. This versatile lubricant contains anti-rust and anti-wear EP additives to provide the corrosion protection in drives and hypoid gears.
Product Specifications
Applications    Auto, truck and bus standard transmissions and differentials requiring API/GL-3 and GL-4 oils
Unit Package Description    1 Gallon Bottle
Brand    Sta-Lube
Generic Description 1    Multi Purpose Gear Oil SAE 85W90
Net Fill    1 Gal
UPC Code    072213242393
Unit Dimensions    10.63H x 4.75W x 6D in
Units Per Case    4
Case Dimensions    11.25H x 11.25W x 13.5D in
Cases Per Pallet    55
Case Weight    33 lbs
I 2 of 5 Code    30072213242394
Appearance    Amber Liquid
Odor    Mild
Flashpoint    >302°F
Flammability    Non-flammable
Specific Gravity    0.89 to 0.91
Plastic Safe    Yes
SAE Grade    85W90
ISO Viscosity Grade    220
DOT Proper Shipping Name    Not Regulated
VOC % (Federal)    None
VOC g/L (Federal)    None
VOC Lbs./Gal. (Federal)    None
VOC Category    Not Regulated
Removal (How To)    Remove with a degreaser or brake cleaner product.
« Last Edit: October 07, 2010, 08:54:08 PM by 1995yj »
97 TJ - I dont wave
Re: Any opinions on GL-4?
« Reply #1 on: October 07, 2010, 09:23:13 PM »
It's good eaten...
 :hitit: :hitit: :hitit: :hitit: :hitit:
RT
« Reply #2 on: October 07, 2010, 09:58:39 PM »
^^^^^^x2
« Reply #3 on: October 07, 2010, 10:02:44 PM »
why 85w90?
just thinking that recommended is 75w90
Offline brokenwrist21
« Reply #4 on: October 08, 2010, 12:33:19 AM »
i run synchromesh myself
« Reply #5 on: October 08, 2010, 08:34:56 AM »
This was the closes thing I could find that wasn't GL-5 at my Napa.  I guess I could try to take it back and order the MT-90.
« Reply #6 on: October 08, 2010, 08:38:27 AM »
It would be better to go with the tried and true in the AX5.  Penzzoil Synchromesh or Redline MT-90.  I wouldn't experiment too much with this, especially with Penzzoil Synchromesh being cheap and readily available.
Offline VA_YJ
  • Now I need a CJ...
« Reply #7 on: October 08, 2010, 03:25:37 PM »
Redline MT-90  is available for just over $10 per quart with free shipping (case price).
http://www.ogracing.com/catalog/2-Car/34-Oils-Lubricants/item-479-RED-LINE-MT-90-MANUAL-TRANS-LUBRICANT
The penzoil is cheaper.  See Jeffy's oil study (FAQs?) for comparison.
« Reply #8 on: October 09, 2010, 12:05:58 AM »
Ok, i bit the bullet for some Redlin MT-90 for $12.50 a quart, 4 quarts worth.  I'll be putting it in my AX5 tomrrow.
I imagine the CRC 80W-90 GL-4 is ok for my rear dana 35?
« Reply #9 on: October 09, 2010, 01:09:50 PM »
For the rears, I use whichever 80W-90 is cheapest and change it often, as every time I get axle deep in water, I change out the oit (and that happens often around here).
« Reply #10 on: October 09, 2010, 05:50:09 PM »
Well, I flushed the tranny and was I shocked.  The oil looked like ivory paint or pancake batter.  Luckily I had some generic gear oil to flush it with before I put in the redline mt-90.  The second drain it only looked like honey mustard.
No more deep water for me.  Vent hose looked ok, but I think its a front seal.  I'll get it next time I have to mess with the clutch.
« Reply #11 on: October 11, 2010, 08:46:23 AM »
I've found that in my differentials a couple of times...  Never in the TC or tranny, though.
