Author Topic: Strange electrical problem  (Read 2030 times)
Barny
« on: December 03, 2010, 07:54:19 AM »
I have a strange and intermittant electrical problem and would appreciate any ideas. Car is a 2000 TJ 2.5 Pertrol. I went out today today see my daughter and the turn indicators were not working. Did a bit more research and discovered that the wipers were also dead. After about an hour of driving around like this they both started working again. Parked up for a couple of hours, then went to head home and both were dead again. Lights, horn and everything else seemed OK. Got home all still dead tried wiggleing all the fuses no change. Went and got a coffee came back and they were working again.
Any ideas much appreciated.
Re: Strange electrical problem
« Reply #1 on: December 03, 2010, 08:41:57 AM »
sounds like the accessory circuit off your key contact (if all the fuses are ok). On my YJ there are 3 fuses fed from that circuit: 1. winshield wipers motor and intermittent control module, 2. turn signal and 3. Cigarette lighter and Radio
On the YJ fuse block there is a circuit braker that powers the winshield wipers (not a fuse), not sure if that's the case on the TJ or not - but if both turn signal and wipers aren't working and just by analogy with the YJ setup I am guessing it's a key contact problem for Accessory power (so the Run circuit is fine as your gauges and engine work).
Check if your hazards are working (they should) and if your radio is working (if it's the same as mine it shouldn't if my assumption is correct).
Barny
« Reply #2 on: December 03, 2010, 09:39:15 AM »
OK Hazards were working OK didnt check the radio, all working again at the moment will check radio next time I can make it fail. It looks like a faulty switch then. I bet they cost a fourtune!!!
« Reply #3 on: December 03, 2010, 11:51:17 AM »
keep in mind that all this is based on my YJ knowledge so please verify first that that's the case for your TJ as well - most likely but i won't be able to tell for sure.
« Reply #4 on: December 03, 2010, 11:58:45 PM »
it is the same, i just found the wiring for 2000 TJ
RUN-ACC A31 circuit powers wipers, turn signal and radio (just like in the YJ) and it comes from the ignition switch to the fuse box at fuses 13, 14 and 15
« Last Edit: December 03, 2010, 11:59:46 PM by sharpxmen »
Barny
« Reply #5 on: December 04, 2010, 06:10:51 AM »
Thanks for that. Its still working at the moment but think I'm going to get a new switch on order.
« Reply #6 on: December 04, 2010, 08:29:59 AM »
could also be the connector or the link in the fuseblock (aside of the most obvious one which is the switch), up to you but i would make sure first before spending the money on a new switch.
