Author Topic: Burning oil bad!  (Read 2741 times)
KILLERtj
Burning oil bad!
« on: February 15, 2006, 11:53:26 PM »
Hello, to start off I have a 2002 TJ with the 2.5L 4 banger.  It just turned 50,000 miles and on a trip home over 800 miles, it burned 8 quarts of oil.  This just started, never burnt a drop before.  There are no leaks visable.  Any ideas on what to check or what to do?
Thank You,
KILLERtj
jwrape
Re: Burning oil bad!
« Reply #1 on: February 16, 2006, 06:05:17 AM »
Quote from: "KILLERtj"
Thank You,
KILLERtj
Yikes, sounds like you burn a piston ring or something. I don't really know what it could be.
Burning oil bad!
« Reply #2 on: February 16, 2006, 09:29:14 AM »
Since you already stated that there is no leaks shown....Check to see if your tailpipe shows the burning of the oil with smoke and residue. Check to make sure your PCV line is clear. Check to see if the air filter is clean.
Then do a compression check. Simple enough to do. You could probably rent the tester from an auto parts store that rents tools.
If the PCV line is clogged, it needs to be clear. It takes the air outside the compression cylinder back into the engine for compression. If this is clogged, there is pressure being built up behind the compression cylider. The air behind the piston on the crank, rods, camshaft, etc.
If there is oil in the air cleaner, you got blow-by, meaning the compression is bad and the compression pressure leaks past the rings and leads into the air cleaner.
Compression check. The numbers between cylinders should be in the 100-120's maybe even more depending on mileage/age, but the cylinders should be 10% within each other for good even compression.
And not being too stupid here, did you check the oil properly and add oil properly. You know of the joke of the blond about the oil?
SMC4WD
Burning oil bad!
« Reply #3 on: February 16, 2006, 11:51:17 AM »
Sounds almost scary to be going through that much oil, and not seeing it go anywhere...
By the way, what does the 710 mean?
lanulos89
Burning oil bad!
« Reply #4 on: February 16, 2006, 12:50:19 PM »
yea i agree with smc 8 quarts i hope that aint ur daily driver.  It sound like it would be the rings if there is no visible leaks.  Is your exhaust whiter than normal?
