Author Topic: Check engine light  (Read 1745 times)
Offline DOTSON53
Check engine light
« on: February 23, 2011, 07:12:52 AM »
Check engine light came on I took it to autozone. They said it was o2 sensor but could'nt tell me witch one. Is there a way of checking what one is bad?
Re: Check engine light
« Reply #1 on: February 23, 2011, 07:49:01 AM »
yes the code should tell you witch one. they prob just didn't know how or there code reader isn't good enough to do it.  should give you a code for pre/post converter
also check if it's a catalytic efficiency code to.. witch could mean it's a converter done..
« Last Edit: February 23, 2011, 07:50:26 AM by Torch_Ind »
Offline DOTSON53
« Reply #2 on: February 23, 2011, 11:08:23 AM »
COOL Thanks!
« Reply #3 on: February 23, 2011, 12:23:52 PM »
what year and eng is your jeep and what code did they say you had?
Offline DOTSON53
« Reply #4 on: February 24, 2011, 06:07:03 AM »
Got it figured out it was the rear o2 sensor. Thanks Again
« Reply #5 on: February 24, 2011, 07:22:29 AM »
:thumb:
hope I was some help
