Author Topic: Auto Shutdown  (Read 1539 times)
OldSchool
Auto Shutdown
« on: February 26, 2011, 05:06:00 PM »
when i stall the jeep with a jerk the auto shutdown will kick in. it takes a few minutes to reset. In traffic this is a problem. Is there any way to turn off or disarm the shutdown.
Re: Auto Shutdown
« Reply #1 on: February 26, 2011, 07:35:39 PM »
there's no kick-in of the auto shutdown, something else must be going on. the auto-shutdown is not an automatic shutdown of the engine but of the electrical system to disconnect some feeds providing 12v during normal operation if the engine is not running - if it is not spinning the relay will disengage (not the other way around as in engaging when not spinning). once you crank it again it will re-engage.
like i said, something else is going on, maybe the same thing that makes you stall the engine is the reason is not starting afterwards.
OldSchool
Re: Auto Shutdown
« Reply #2 on: February 27, 2011, 07:21:47 AM »
Thank You very much.
