Author Topic: Another 30rh question  (Read 11142 times)
Offline MarkyB
« on: March 17, 2011, 06:25:32 PM »
My issue is the torque converter can't make up it's mind.
Under acceleration, the transmission acts and shifts normally.
At cruising speed, it will lock up.  But the smallest of throttle changes will cause it to unlock momentarily then lock back up.
I've had it do this 3 times in the span of a couple of seconds.
I recently did a 4.0L throttle body swap and spacer.  I readjusted the kickdown cable per the FSM after the swap.
This is a recent development, after the swap.
Re: Another 30rh question
« Reply #1 on: March 17, 2011, 08:24:09 PM »
did you put a spacer (spacers to be more exact) under the cable bracket? if you didn't that's most likely your problem. You can make your own out of some 1/4'' pipe (EDIT: they should be the same size as the thickness of the t/b spacer)
« Last Edit: March 17, 2011, 08:25:23 PM by sharpxmen »
« Reply #2 on: March 18, 2011, 06:00:01 AM »
If it didn't do this before the TB spacer install, it's likely the throttle cable bracket on the manifold like mentioned ^^.  You can also grab some threaded couplers from the hardware store that are 1" long and large enough for the TB bolts to slip through, or I can send you the real deal LOL.
You will need longer bolts for the bracket, 6mm x 40mm is what I use.
Offline MarkyB
« Reply #3 on: March 18, 2011, 10:14:56 AM »
I'll have to go dig thru my pile of nuts/bolts/parts/junk.
I bet I already have something that'll work.
I haven't thought about raising the cable bracket.
Thanks!
« Reply #4 on: March 18, 2011, 10:18:11 AM »
The 4banger is a real dog with the auto, can I ask why you made the change?
« Reply #5 on: March 18, 2011, 10:52:17 AM »
same reason everyone else putting bigger t/b on there 4banger,, no?
Offline MarkyB
« Reply #6 on: March 18, 2011, 11:28:53 AM »
There is another 30rh thread where the guy swapped his trans.
Mine was auto when I got it.
The TB swap made a world of difference on it though.
« Reply #7 on: March 18, 2011, 01:05:38 PM »
No, quite the opposite.
« Reply #8 on: March 18, 2011, 02:19:55 PM »
so because it's auto the 4.0L throttle body swap makes less power???
your not making any cents!!
« Last Edit: March 18, 2011, 02:21:15 PM by Torch_Ind »
« Reply #9 on: March 18, 2011, 02:26:25 PM »
he's was asking why the 30rh swap from manual transmission (misunderstanding, that was another member in another thread) and not why he swapped the t/b
« Reply #10 on: March 18, 2011, 02:29:49 PM »
lol he even quoted me saying
Quote from: Torch_Ind on Today at 12:52:17 PM
maahahahahaha
not prob dude lol.
and its a 30rh question not swap!!
« Last Edit: March 18, 2011, 02:31:32 PM by Torch_Ind »
« Reply #11 on: March 18, 2011, 03:18:47 PM »
maahahahahaha
not prob dude lol.
« Reply #12 on: March 18, 2011, 04:22:43 PM »
sharp he posted this after the fact they had already cleared all that up not to mention there is nothing on this thread stating he did a manual to standard swap when I posted my question about specifically a big t/b
Quote
This was said before he replied to me
Quote
I get what he assumed but he didn't read it. everything was stated before he replied to me
« Last Edit: March 18, 2011, 04:26:34 PM by Torch_Ind »
« Reply #13 on: March 18, 2011, 04:31:43 PM »
yeah, i made the connection with the other thread as i replied to that one, i see what you mean.
« Reply #14 on: March 19, 2011, 09:12:44 AM »
Yes I thought both 30rh threads were by the same person, I should have looked closer.
Torch, I thought your question was in reference to me asking why the 30rh swap, not why the 4.0 tb swap.
Much about nothing.
