Author Topic: question regardin TB spacer  (Read 8879 times)
Offline andpgud
Re: question regardin TB spacer
« Reply #15 on: April 16, 2011, 05:04:27 AM »
What would you say if I would get a stock 4L TB and a 55mm, 1" wide spacer and bore the Intake manifold to 55mm?
How would that work out for the 2.5?
« Last Edit: April 16, 2011, 05:04:57 AM by andpgud »
« Reply #16 on: April 16, 2011, 07:46:53 AM »
I Run a custom TB spacer which is 60mm top side and tapers to 55mm bottom side. Helps keep air pressurized coming in which maintains torque through out the power band. Works for me.
that would be a nozzle which would increase velocity and decrease pressure according to Bernoulli equation (simplification)
take a look at the picture on right side of the wiki link.
http://en.wikipedia.org/wiki/Bernoulli%27s_principle
you have to have the same flow rate through the entire system so when you go to a smaller diameter the velocity has to go up to maintain the flow rate.  Bernoulli equation has velocity, pressure, and gravitational potential terms, in this case (1 inch drop) gravitational potential change is quite small, so for the increase in velocity you lose pressure.
Offline andpgud
« Reply #17 on: April 16, 2011, 08:33:53 AM »
So 55mm all the way should do the job?
« Reply #18 on: April 16, 2011, 09:01:37 AM »
It's more than the stock one so it does gain a bit of performance. The 62-64mm ones even more so.
« Reply #19 on: April 16, 2011, 09:55:03 AM »
these are 64mm
comparison 2.5 vs. 4.0 vs. 64mm
quicksand
« Reply #20 on: April 16, 2011, 11:44:53 AM »
Nice 64s, do you also bore the manifold that big on a 2.5L?
« Reply #21 on: April 16, 2011, 12:07:29 PM »
these are 64mm
There are rules against posting PORN PICS here.  :nono: Might have to give you a timeout!  :lol:
« Reply #22 on: April 16, 2011, 01:06:28 PM »
yep, and round the edges under the bore
fixed, should be gone in a bit
« Last Edit: April 16, 2011, 01:07:34 PM by sharpxmen »
Offline andpgud
« Reply #23 on: April 16, 2011, 05:44:45 PM »
I would like to get those photos bakc :(
« Reply #24 on: April 16, 2011, 05:49:13 PM »
You know I was teasing about the Porn bit, right?   :drink: Bring em back.  :lol:
« Reply #25 on: April 16, 2011, 07:36:35 PM »
they're back
« Reply #26 on: April 16, 2011, 10:27:50 PM »
they're back
Thanks for bringing back the eye candy!  :naughty:  :hump:  ;)
Offline andpgud
« Reply #27 on: April 18, 2011, 04:47:15 AM »
With doing the TB thing and with the spacer, do you get better MPG?
« Reply #28 on: April 18, 2011, 08:26:16 AM »
unlikely, as you get better response and probably drive faster it might get worse. It's more about the way you drive than anything and based on how this would fit your style of driving could go either way.
