Author Topic: how come my 95 jeep is bogging down?  (Read 17355 times)
Offline brokenwrist21
Re: how come my 95 jeep is bogging down?
« Reply #60 on: May 14, 2011, 09:05:06 PM »
mine had the same symptoms a couple years ago on the way to work, all of sudden wouldnt accelerate, then it suddenly would, with a massive back fire, i figured either my cat fell apart inside and was blocking exhausr flow or my muffler fell apart inside and was blocking exhaust flow. either way, after it didt that it drove fine, finally replaced the cat and muffler, drives even better now
« Reply #61 on: May 14, 2011, 11:07:57 PM »
I had similar symptoms a couple of times, and both times it ended up being the coil...
