Author Topic: hp dana 44 advice  (Read 5270 times)
Dylan
Re: hp dana 44 advice
« Reply #15 on: May 06, 2011, 07:32:02 PM »
on the rubi only the center housing is D44, the tubes are D35 size or D30 for the front. still the axles are 30 splines but i think is the same bearing and c-clip in the rear as on the D35.
Just a note, the TJ/LJ Rubicon D44 is bolt in, not c-clip.  Additionally, the tubes for TJ/LJ axles rarely present a problem... the D35 housing flexing and the skinny stock axle shafts are the most common complaints/sources of failure.
« Reply #16 on: May 06, 2011, 08:39:24 PM »
you're probably right, i was most likely picturing the GC one. the tubes are still weak though regardless of the center they will flex, a truss would fix that problem. I have no idea why they used smaller tubes, beats me.
