Author Topic: wierd noise!  (Read 2361 times)
sailorjerry13
wierd noise!
« on: June 14, 2011, 05:42:56 PM »
Hi everyone, hope u guys are doin well, I have a question about a weird noise that started a few days ago, it sounds like I'm dragging a chain and it seems to be comming from the bottom rear of my yj I notice it more when I take off in 1st gear or when comming to a stop but its always when moving, any thoughts?
Re: wierd noise!
« Reply #1 on: June 14, 2011, 06:26:35 PM »
Crawl under and see if there is any movement in the U joints on the drive shaft. (grab the drive shaft and give it a good tug and pull)
Re: wierd noise!
« Reply #2 on: June 14, 2011, 09:00:15 PM »
there is a chain in the transfer case...
make sure you're not in 4wd by any chance and that the tensioner cap is there (on the underside of the t-case)
otherwise on top of what he ^ said i would check fluids in rear diff, t-case and transmission. also make sure the transmission mounts are sound (center and anti-torque), long shot but have a look while you're under there anyway.
sailorjerry13
Re: wierd noise!
« Reply #3 on: June 18, 2011, 05:49:14 PM »
4 banger yj was right, drive shaft had play so i changed the u joints and problem solved, thank u very much for the help
Re: wierd noise!
« Reply #4 on: June 18, 2011, 08:56:49 PM »
 :thumb:
