Author Topic: Alternator Bible from Billavista  (Read 2516 times)
« on: December 22, 2011, 01:15:48 PM »
http://www.pirate4x4.com/tech/billavista/Wiring/Part2/
Saw this and thought of you Jeffy. Not that we run the Delco brand Alt. But lots of good info.
Re: Alternator Bible from Billavista
« Reply #2 on: December 22, 2011, 01:29:48 PM »
What's up with yours? Bad bearings or are you looking for more amps?
« Reply #3 on: December 22, 2011, 01:36:11 PM »
Bearing howls.  170A is plenty of juice.  75A, not so much.
« Reply #4 on: December 22, 2011, 03:38:14 PM »
I thought you were running one of the Dakota ones? 150 amp??
« Reply #5 on: December 22, 2011, 04:18:10 PM »
Dakota/Caravan/GC Jeep is 136A.  Mine is a 170A modified Caravan alternator.
« Reply #6 on: December 22, 2011, 05:40:54 PM »
Well, I found out the rear bearing is original.  Also, taking the screws out was a PITA.  I ended up having to push the brushes in to clear the rotor without removing the brushes and rectifier.
I measure 15mm ID x 35mm OD x 11mm W for the rear and 17mm ID x 52mm OD x 16mm W for the front.  The front bearing is a KOYO 437.  The rear is WBD 6020D.  Looking up the numbers on the small bearing, I get this;
Ball Bearing
Dbl. Sealed
For:
Bosch ER/EF, IR/EF, Delco AD230, AD237, AD244, CS130D Series IR/IF (S.R.E.); Hitachi, Mitsubishi, Nippondenso (D.E.); Lucas Generators (D.E.); Nippondenso 3.0kW, 5.5kW OSGR Starters (Armature)
Replaces:
Bosch 1-100-900-000
Delco 10475023
Lucas 54160090, UMB109, UTB100
Ref. No. 6202
Dimensions:
AMSCO#: 333RR
WAI#: 10-3042-4
ACE/ACCURATE#: A-6942-2S
OEM#: 949100-3330, 949100-4370, 949100-5010
FITS: NIPPONDENSO ALTERNATORS (D.E.)
DIMENSIONS: 17MM X 52MM X 16MM
« Last Edit: December 25, 2011, 12:16:57 AM by Jeffy »
« Reply #7 on: December 23, 2011, 10:01:08 AM »
Have you found a source to buy from?
Did you find anything else wrong with it?
« Reply #8 on: December 23, 2011, 02:54:44 PM »
The small bearing has some play.  You can hear it when you spin it.  The big one feels like it's spinning in molasses.  I don't feel any rough spots but its not spinning freely.
There are a bunch of places to get bearings.  Ebay, any alternator rebuilder, bearing supply, etc...  Even Napa has some.  Although they're a bit overpriced.  The big bearing goes for $15-30.  The small one $8-10.
« Reply #9 on: December 23, 2011, 04:17:54 PM »
I could always put those bad bearings to use on something or another. Maybe after the Christmas hub bub is over you could send them down. I'll pay for shipping.
« Reply #10 on: December 24, 2011, 12:17:05 AM »
This place seems to sell them.  Only problem or potential problem is quality.  They look to be from China.  I don't know of Timken make any or Valley Forge or any of the other US makers though.
http://www.smithcoelectric.com/servlet/the-306/949100-dsh-3170-949100-dsh-3660-949100-dsh-3670-A-dsh-8002-dsh-2S/Detail
http://www.smithcoelectric.com/servlet/the-229/949100-dsh-3330-949100-dsh-4370-949100-dsh-5010-A-dsh-6942-dsh-2S/Detail
« Last Edit: December 27, 2011, 03:51:13 PM by Jeffy »
