my point was running the straight axle to eliminate the vacuum disconnect. So I can use any xj or tj axle for that?
Yes, that will worn BUT your front driveshaft will not turn 24/7. YJ driveshafts aren't balanced so you might get some vibrations at higher speeds. Also, some people add seals to the axle housing to keep them from leaking. I'm not really sure if this is necessary since mine don't leak.
