Author Topic: More Oil Capacity and Filtering Cheap  (Read 9248 times)
« on: September 25, 2005, 01:02:28 AM »
This one is a old one but still, not that many people know about it.  Jeeps since the mid-80's like the Wrangler, Cherokee and all current Models use a standard oil filter. In most cases, it will be a Fram size PH16. These are small filters. Shorter then a soup can.
A simple and inexpensive way to get more oil and filtering capacity is to move up to a larger filter. Now you will need one that has the same thread pitch as the old one. Not only that but the seal at the bottom has to be the same size also.  The way to check the filter is to get look for a size that will work and compare the oil seal and thread.  If you know you know what to look for in a decent filter then take a peak inside too.
One filter that is very easy to get a hold of is the Fram size PH8a. This filter is 1.5x larger then the stock filter. This means it will hold that much more oil and filter that much more. Not to mention PH8a's are used across many different cars so they are usually on sale. 2 for $6 isn't a bad deal.
Part Number PH8A
Product Type   Full-Flow Lube Spin-on
Anti-Drain Valve   YES
Product Height   5.14"
Product I.D.   3/4-16 Th'd
Product O.D.   3.8"
Relief Valve Setting PSI   12
Style Code   1
Application Example   1995 Ford Mustang GT V8 5.0
Cross-Referance:
    AC DELCO PF2
                    PF2CL
                    PF32
                    PFL1A
                    PFL1ACL
                    UPF2
                    X14
    ADVANCE AUTO PARTS AA8A
    AMSOIL ASF15
    BOSCH 0451104001
               0451104003
               0451104065
               0451203005
               0986452001
               0986452002
               3500
               72102
               72102WS
    CANADIAN TIRE 1717042
    CAR CARE PARTS OF1
                              OF8
    CARQUEST 85515
                     B1A
                     R85515
    CASE A17415
             A33487
             E36534
    CATERPILLAR 313658
                        314361
                        329060
                        364464
                        3I1081
                       773673
    CLARK EQUIPMENT 3981923
                                 899839
                                 899899
    CONTINENTAL ENGINES TM27L00312
                                        TM27L03100
    DAEWOO A251025
    DAF 494133
    DAIHATSU 1560087320
                    1560144010000
    DENSO 1501004
    DENYO 1150100028
    DEUTSCH D539
    EVERGARD E1A
    FACET AUTOMOTIVE 8
    FAIRBANKS-MORSE 9097
    FARMLAND FER1A
    FEDERATED LF115F
                      PH8A
    FERRARI 45384000
    FORD 59W18660
             9500462
             9613330
             B7A6714A
             B7A6731A
             B7A6731B
             B8A6731A
             B9AE6714A2
             B9AE6714A6
             B9AE6714B
             B9LE6714A
             C1AZ6731A
             C1AZ6731AP
             C3NN6714A
             C4AE6714A
             C4AF6714A
             CC1AZ6731A
             COAE6714A
             COAE6714B
             COAE6731A
             COLE6714A
             D8NN6714GA
             D9AE6714AA
             D9AZ6731A
             E2AE6714B1A
             E3ZE6714CA
             ESE1ZE6714AA
             O9AZ6731A
    FRAM DG8A
             HM8A
             PH28032
             PH32
             PH8
             PH8A
             TG8A
             XG8A
    GENERAL MOTORS 25162815
                                5575840
                                6438121
                                7984292
                                9002514
    GOODYEAR 2224501
                      L8A
    HINO 1560A41010
    IAPCO A0261005
              A0280001
              OF115
    IHC 285451A1
           388227
           920203
    INGERSOLL-RAND 35303692
                               35366681
                               40210
                               59438820
                               91677369
                                92128859
    JAPAN FILTER CO. JO205
    JIFFY LUBE HL3
                     HL8A
                     JL119
                     JL13
                     JL1A
                     L30001
    JLG 7021869
    JOHN DEERE TY9425
    K&N HP3001
    KENDALL K1
    KNECHT AW1
    KNECHT FO371
    KNECHT OC4
    KNECHT OC61
    KNECHT OC67
    KOEHRING 8023398
    KRALINATOR L22
    KUBOTA 1540232091
                 1540232430
                 1583132430
                 7000014689
                 7000032090
                 HH15132430
    LAZORLITE DT152
                     DT155
                     L111201
    LEDERER LER1
                  LER1A
    LEE LF1
          LF1A
          LF1HP
    LETOURNEAU WESTINGHOUSE KC5042
    LISTER 392528
    LPM 00013505015
           13504918
    LUCAS (ALSO SEE CAV) F414
                                       F4644
                                       F5537
                                       F6203
                                       F678
    M.A.N. 00024151017
    MACK 485GBS1138
    MAHLE/KNECHT OC374
    MANITOU 171549
    MANITOU 171550
    MANN FILTER ML1004
    MANN FILTER W7172
    MANN & HUMMEL W9308
    MANN & HUMMEL W936
    MANN & HUMMEL W9401
    MANN FILTER W94080
    MANN & HUMMEL W94081
    MASSEY FERGUSON 1900365M91
    MASSEY FERGUSON 4223058M1
    MASTER PARTS PH2850
    MASTER PARTS PH8A
    MAZDA ZZL014302
    MOBIL MO1A
              MO1ABP
              MO257
              MOF1
    MOBIL 1 M1301
    MONROE 39201
    MONROE FP100
    MOPAR 0FE00148
                1719635
                1739617
                1739618
                1851658
                1944888
                2063991
                2205517
                2471400
                2532744
                2555929
                2647019
                2806201
                2951957
                E5778M
                E5779M
                J0927787
                J0936406
                J0938143
                J3153230
                J8051330
                J8990499
                L1007
                L138
                L324
                L72
    MOTORCRAFT FL1
                         FL1A
                         FL1DP
    NAPA 1515
             41515
             21515
             31515
    NEW HOLLAND 500462
    NEW HOLLAND 508129
    NEW HOLLAND 76595295
    NIPPON 1150100392
    NIPPON 1150100393
    NISSAN 1520865001
                1520865002
                1520865010
    OREILLY PROTEC MP 101MP
    PENNZOIL HPZ1
                    PZ1
    PORSCHE 90110720301
                   90110720302
                   90110720303
                   90110720305
                   90110720309
                   911901107
    PUROLATOR BASE L30001
    PUROLATOR BASE L30119
    PUROLATOR BASE L30341
    PUROLATOR MF45700A
    PUROLATOR MF45700B
    PUROLATOR PC25
    PUROLATOR PC34
    PUROLATOR PC341
    PUROLATOR PER1
    PUROLATOR PER1A
    PUROLATOR PL30001
    PUROLATOR TBO1
    QUAKER STATE QS8A
    STEYR-DAIMLER-PUCH 21785820
                                      712071142
                                      7121071142
    STP S01
          S8A
          STP1
    SUNOCO O1
                  O1A
                  S72
    SUPERTECH ST8A
    TOYOTA 0060290915007
                 1150100381
                 1560041010
                 156007600371
                 1560120550
                 1560120560
                 1560141010
                 1560144010
                 156014401083
                 156017810171
                 1560196101
    UNOCAL 76 PF2
    UNOCAL 76 PF2A
    VALVOLINE DF1
    VALVOLINE VO1
    VW GROUP 911901107
    VOLVO 835779
    WAL-MART WF1
    WARNER PH8A
    WARNER WPH8A
    WHITE 159045S
    WHITE 312770467
    WHITE 36031200
    WHITE 400000407
    WILLIAM PENN WP8A
    WIX 51515
    WIX XP 51515XP
** CJ's and Early YJ's use a 16mm Metric thread for the oil filter.  This will be a PH3387a.  For those who have a metric filter,  try a 3980.  Owners should also be able to convert to a standard thread filter.
« Last Edit: August 08, 2026, 03:20:57 PM by Jeffy »
