General Forums => The Mess Hall => Topic started by: 4bddn on September 12, 2009, 07:36:45 AM
New to this frum, so if this question has been asked...my apologies. Ive got the 2.4L and I see lots of articles about swapping a 4.0L tb on the 2.5L motor...but nothing on doing the same with the 2.4L. Is this even possible? Thanks
if i remember correctly the 2.4l has a different bolt pattern for the tb so it wont work....
snap...thats not what i wanted to hear :'(
if that's the only problem (difference) you can always make an adapter (e.g. something like the spacer with countersunk holes for the intake bolts and threaded holes for the t/b - a piece of 1/2'' aluminum will do) - but question is will the other things bolt right in: tps, map, IAC?
I would look toward other Chrysler products, maybe with a turbo 2.4L or otherwise, and see if they have a larger TB that will swap on.
Look for pt cruiser soup up stuff. Or some parts of the 2 door chrysler sports thing cannot think of the name right now is a little sportscar with a turbo 2.4
Still the little 2.4 does alright as it is
dodge neon maybe (i mean if that's what you were thinking of)?
i know only of the jeep 4.0 tb dimensions. i htink they are a 58mm bore. any ideas on the pt cruiser or neons?
srt4 aka neon
kinda like this?
http://cgi.ebay.com/ebaymotors/UNIVERSAL-80MM-THROTTLE-BODY-DODGE-NEON-SRT-4-SRT4-TSX_W0QQcmdZViewItemQQ_trksidZp3286Q2ec0Q2em14QQhashZitem19b4ae1328QQitemZ110405489448QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
80mm sounds a bit big for a 2.4L four, but who knows. I'd be weary of the following in the Ebay auction:
# Universal fit to most car, come with adapter plate that you can weld on a intake manifold.
# Included a place to bolt on TPS (Throttle position sensor).
# No instructions included. Professional installation is highly recommended.
i agree. more of a comparison of tb's just to get an idea of things. i think the upgraded tbs are 62mm...much smaller than the 80mm on ebay! but, ive seen going from a 2.5L tb toa 4.0L tb, just never anything about the 2.4L
