General Forums => The Mess Hall => Topic started by: FourbangerYJ on November 20, 2009, 11:02:15 PM
A friend of mine has a 90 W/ 2.5L and is looking for a metal valve cover. I snooped around a bit and did not see any metal ones, lots of plastic thou.
Does it exist?
I don't think so.
My 94 has a cast Aluminum stock valve cover. So maybe check wrecking yards?
>1990 have aluminum valve covers but for some reason I don't think they'll work on a TBI system.
when i got my 1990yj it had a cracked valve cover and couldn't find a metal one so i settled for a plastic one.. but for some reason the dealer couldn't' get my the correct gr-omits for the pcv system (after like 4 tires i gave up and used silicon to fill the gap in the wrong grommet.) they would either get a grommet that fit the valve cover or one that fit what goes into the valve cover... if i had to do it again id get a metal one for the 1991+ and change the pcv system over (shouldn't realy be that different or effect the fuel injection as long as you have air in and out.
The +91's do not use a PCV system.
(http://img1.classistatic.com/cps/kj/091115/178r3/80516nm_20.jpeg)
I have this one up for grab's it's not plastic.
Is that what your looking for?
What would it take to make the 91 and newer work on the 90 and older?
Anyone have a PIC of the 90 style?
TORCH: that is what he is looking for. Seems there is the question if it will work with the TBI VS. MPFI.
This is the best picture i have and doesn't realy show the contoures of it.. jut what sticks out of it...
(http://i164.photobucket.com/albums/u25/chardrc/jeep/IMG_2962.jpg)...
looking at pictures and part numbers on autozone.com comparing 1990 to 1991, I found that they have different part numbers (but the 1990 was a rubber gasket and the 1991 was cork rubber :confused:) the pictures do look like the shape is slightly different (more ins and outs with the metal one) if that can be trusted. :confused:
edit: found picture on quadratec web site
(http://www.quadratec.com/Assets/Images/114855/114855-md.jpg)
I had issues with leaks and called felpro's tech line.
Wonder of wonders I ended up talking to a guy who knew his stuff, and was a YJ owner.
There are 4 different 2.5 liter valve cover gaskets. 2 plastic and 2 metal cover variants.
You have to look at teh cover, teh key difference is whether the cover has pinch points near the bolts.
The 91+ valve cover has the extra fitting for the metered breather fitting. The early one has a PCV can.
With some minor adjustments they should interchange.
well I'm selling the one I posted if your interested let me know
By the looks of it, it won't work.
What are you seeing that looks different? Just curious... Cause all 2.5 use the same head.
One has 3 holes the other only 2. I would imagine it would bolt to the head. What do you do about adding a hole? Just drill it, it looks pretty large.
You mean the holes for the hoses and such? or the mounting holes?
On a MPI you have a breather connection and a fitting for crankcase metered breathing. (CCV is a small brass fitting like 1/4 inch on side of cover.)
On the TBI you should have a breather and PCV valve. (PCV and Breather are like 3/4 in holes on top of cover.)
You might be able to find a Breather cap to replace the oil filler cap and use the original breather for the PCV valve?
I might be missing one,,, What do you see on yours?
the metal one has 3 holes.. one of them is open the side.. but they are different sizes...
