General Forums => The Mess Hall => Topic started by: RT on August 11, 2010, 11:56:15 PM
Title: Best Aftermarket muffler for 2.5 liter?
Post by: RT on August 11, 2010, 11:56:15 PM
Hey I was looking for a good aftermarket muffler for the 2.5. I was just looking for the performance boost and don't care about the sound as long as it isn't deafening. I was thinking a flow50 or even one of the high end cherry bombs....i'm on a BUDGET :fitz: :fitz: :fitz:   Any advice?
Title: Re: Best Aftermarket muffler for 2.5 liter?
Post by: Jeffy on August 12, 2010, 01:12:53 PM
I would go with a Magnaflow for $50 or a Borla for $114.  FlowMasters suck for a 4cylinder.  A Cherry bomb even worse then a Flowmaster...  If you like noise then get a Flowmaster or better yet a Cherry Bomb.  With both of these you'll probably see a drop on Torque but you'll probably gain a little HP on the high RPM (over 3600).  I've had a Flowmaster break off because of quality issues.  At what they charge, there is no reason they shouldn't use stainless steel like every other band.  Mine broke at a weld and proceeded to fall off while in traffic.  Ended up cutting it all and replacing the whole setup with a cat-back.
If you don't weld the muffler on you could probably piece meal a complete cat-back.
Post by: BlueFlu on August 12, 2010, 03:30:32 PM
The new Cherry Bomb Welded (Flowmaster clonish) sounds good. I've been running one since last fall.
Magnaflow would be a good choice also.
Post by: 97 TJ - I dont wave on August 12, 2010, 09:43:56 PM
I replaced my rusted through blown out 1 year old Borla muffler after they crawfished me on the warranty, with a MagnaFlow several years ago. Very happy with the MagnaFlow, I have the Magna flow cat as well which creates only 1 pound of back pressure.
Post by: RT on August 12, 2010, 11:18:09 PM
so what model magnaflow?
Post by: RT on August 13, 2010, 12:02:57 PM
i just talked to the muffler guy, he said that a magnaflow would work  best and i shouldn't worry bout losing all my torque because i'm running a stock cat.....bs or no?
Post by: 97 TJ - I dont wave on August 14, 2010, 09:58:29 PM
RT... You are splitting hairs when you mention four cylinder and torque in the same sentence. Buy the Magnaflow and the money you save you can invest in a good Chia Pet.
Post by: Torch_Ind on August 15, 2010, 06:55:50 PM
I'm running cherry bomb vortex muffler and LOVE it!!..
(http://www.performancepeddler.com/images/CherryBomb/vortex-cutaway_lg.jpg)
Post by: RT on August 15, 2010, 09:32:53 PM
does it fit the stock pipes?
Post by: RT on August 15, 2010, 09:35:52 PM
....ok that's good, my old one just died  :'( :'( :'(
Post by: Torch_Ind on August 16, 2010, 04:18:16 PM
I'm running a 2.5inch one but you can get them what ever pipe size you want.
http://www.cherrybomb.com/products/vortex (http://www.cherrybomb.com/products/vortex)
Post by: sharpxmen on August 16, 2010, 04:38:31 PM
how loud is it?
Post by: Torch_Ind on August 16, 2010, 05:12:34 PM
how loud is it?
mine is a bit louder but I have 2.5inch full exhaust no cat and header and 62mm tb and ported intake.  when I step on it it will breath!!!  If I can get a camara I will record it ok.
Post by: RT on August 16, 2010, 08:29:28 PM
thanks a million, it's kind of a crap shoot finding exhaust for a 2.5 liter...and i really appreciate the help :beers:
Post by: Eucalypta on August 20, 2010, 05:31:26 AM
Here in the Netherlands, we have a dealer who helps you choose the right one.
He just installs one, let you hear it, then installs the next until you tell him it's ok.
Got a stainless steel cherry bomb under my 2.5.
When idling or at "normal" pace; it is pretty quiet.
When pushing the throttle there is a deep dark rumble.
I like the sound alot.
Costs about €80,=
Post by: Torch_Ind on August 20, 2010, 10:38:34 AM
Costs about €80,=
mine isn't stainless but it's heavy steel and his sound description is about the same
Post by: Complete Loser on August 24, 2010, 10:05:20 AM
http://www.cherrybomb.com/catback/15/83   Here is what Cherrybomb recommends for jeeps.
Im running the crappy Raptor (already was on th Jeep) and it sounds gay. So I was at Autozone and asked them for the quietest muffler they had in 2.5". They gave me a Cherrybomb Turbo. So i stuck it on behind the Raptor. Quieted it down a good bit.
To make a tail pipe, i just grabbed some 3" that i had laying around. I was in a hurry. Then I got around to actually doing it right. I stuck about 3ft of 2.5" pipe on over the axle and turned out.
Just changing the tailpipe dia made a difference in performance. I noticed that it now takes me just a tad longer distance, to accelerate up to any given speed. But I now seem to have a tad more power when accelerating up hills/inclines.
Post by: RT on August 27, 2010, 02:29:44 PM
so would exhaust help out with turning bigger tires (like 31 or 32) or an I just wasting my money :fitz:
