General Forums => The Mess Hall => Topic started by: C.Redbeardd on January 31, 2011, 01:25:23 PM
So my SM465 transmission was installed about 6 months ago. I cant notice any obvious leak on the tranny. Its just leaking onto the skid plate and dripping off that. It only leaks after I have been driving it and the oil is warm and thins out. Around town its not bad and only a couple of drops. But when I drive it on the highway for about an hour or more is when it gets bad. It will just puddle up under my jeep. Its got a novak adapter to the transfer case.. Thats the only spot I think it might be leaking.. Is there any reason that it might be leaking through that adapter and/or any suggestions how to fix this, if that is the case? Any more places I might look for a leak?
Thanks, it just gets annoying. Any help would be great.
does it have a vent tube? or just a vent hole on top of the tranny, maybe the tube is pulled and sips out at high speed/high temp when the fluid gets thin.
did you use rtv on the adapter on both t-case and transmission side, looks like it seals the transmission fluid on the mating surfaces (so that can be the case like you mentioned).
Bad seal, pinched seal, dry seal...You could do the talc powder trick to see where it's leaking form exactly. Run teh Jeep then when you park it, wipe down the transmission then hit it with some talc. and them come back later.
I think it may be a bad seal of rtv around the adapters. But the seals should be good. The thing was completely rebuilt.. Hmm.. Thanks for the suggestions guys. I'll have to drop the skid one of these days when I find time.
I never use rtv on transmissions, always a paper gasket coated both sides with copper coat.
Yes its a bitch to get off, but I hate leaks... Manila file folders make great paper gaskets in a pinch....
Hmmm... thanks. Guess I learn something new everyday. Haha.
