Author Topic: Floor  (Read 1602 times)
jcrockarell9937
Floor
« on: June 22, 2011, 06:03:34 PM »
So I've been noticing everytime it rains and i drive my floor in the jeep becomes soaked. I have carpet and it becomes like a wet towel. I have pulled the carpet up some and the tub is water filled. I haven't noticed any OBVIOUS leaking.  Like i said, this is just from driving in the rain. I haven't took the jeep through water. Any ideas on what the problem is and a solution?  Thanks
98 TJ by the way
Re: Floor
« Reply #1 on: June 22, 2011, 07:01:20 PM »
the seal between the body and the windshield if fairly common water source. as is the cowl seal. I've also had water leak in form the bolt holes that hold the soft top rail to the top of the windshield. take a look at jeffy's ongoing water leak thread.
Re: Floor
« Reply #2 on: June 22, 2011, 09:01:42 PM »
I've chronicled all my leaking problems.  Some of it's in my Joop build but you can find the main thread here: http://4bangerjp.com/forums/index.php/topic,7808.0.html
It finally doesn't leak anymore.  :wall:
95yjman
Re: Floor
« Reply #3 on: June 23, 2011, 12:26:39 AM »
Mine only leaks if its a really hard rain heh
