Author Topic: stalling  (Read 3080 times)
fireman411
stalling
« on: July 13, 2011, 09:08:48 PM »
its been a while but I need some help. My 90 yj after running for a little bit will drop idle and stall out. I have changed the plugs,wires,cap,rotor, fuel filter. It will only do it if it has th hose on it going from the air box to the TB. I can not figure it out to save my life.
Re: stalling
« Reply #1 on: July 14, 2011, 09:42:37 AM »
not sure which hose you are referring but have a look at the air filter (just because you mentioned the airbox)
Re: stalling
« Reply #2 on: July 14, 2011, 10:45:13 AM »
Think the MAP Sensor is getting a false reading because the hose is off.
Re: stalling
« Reply #3 on: July 14, 2011, 06:02:18 PM »
you must be talking about the vacuum line for the hot air vacuum operated door in the air box. it applies vacuum to open the door and if the tube from the air box to the exhaust manifold is still there would start partial shutting ounce the exhaust manifold heats up and gets the air hot... don't really see how that vacuum door system could kill the jeep. would only see it leaking and causing a high idle.
Re: stalling
« Reply #4 on: July 14, 2011, 06:09:58 PM »
only if the line going to the MAP sensor is off, damaged or plugged will cause false readings, having another line off or a leak does not cause false reading, it just reads the correct (less) vacuum and the idle would be higher due to more air entering the engine. If it was a MAF sensor then you'd be correct (the additional air entering the engine would bypass the MAF sensor), with MAP the vac leak theory does not apply.
Re: stalling
« Reply #5 on: July 15, 2011, 10:29:34 AM »
So it runs ok with the hose disconnected?  This sounds like the hose gets blocked off when attached.
Re: stalling
« Reply #6 on: July 15, 2011, 12:12:35 PM »
so if it runs with it off and not on i would think the idle control actuator motor is closing the throttle too much and needs the extra air from the open vacuum line to run.. seems odd... if it is as described i would take a volt meter and test the tps adjustment.
fireman411
Re: stalling
« Reply #7 on: August 14, 2011, 06:02:46 PM »
OK well I have changed the coolant temp sensor and map sensor. Still doing the same thing also replaced the hose coming off the map sensor. I am lost.  :brick:
Does anyone think it might be a timing issue? Im shooting in the dark now
Re: stalling
« Reply #8 on: August 14, 2011, 06:57:36 PM »
could it possibly be the egr being opened at idle (which shouldn't happen but would kill the engine, easy enough to check also without spending any money).double check you lines and try capping off the egr and see if it still cuts out.
Re: stalling
« Reply #9 on: August 20, 2011, 08:27:18 PM »
Do you have a scan tool? What DTC codes are you getting: Stored before you start it and once it dies?
Re: stalling
« Reply #10 on: August 21, 2011, 06:25:33 PM »
this is 1990 tbi, doesn't store codes and scan tools are few and far between.
