Author Topic: Tie Down Straps  (Read 2492 times)
Offline VA_YJ
  • Now I need a CJ...
Tie Down Straps
« on: July 28, 2011, 08:31:59 AM »
I'm in the market for some heavy duty tie down straps for hauling Jeeps on a trailer.  I'm thinking four 4" straps.  Does anyone know of a good (inexpensive) source for HD tie downs?
Thanks!
YJWralph
Re: Tie Down Straps
« Reply #1 on: July 28, 2011, 11:06:43 PM »
For hauling anything rubber-tired on a deck trailer, you should always use chains and boomers.  And always cross-chain.  No chance of it falling off, then...  :beers:  I don't know where you would get them in the States, though.  Semi Truck parts stores, maybe even Harbor Freight?
Offline VA_YJ
Re: Tie Down Straps
« Reply #2 on: July 29, 2011, 09:30:00 AM »
Thanks for the advise.  I will look for chain tie downs with tensioners.  Don't want to lose anything off the trailer...
AZDoug
Re: Tie Down Straps
« Reply #3 on: August 02, 2011, 05:22:17 PM »
You could look at some of the tow truck supply sites, all kinds of straps and ratchets. WE buy from   http://www.awdirect.com/
If you look at car transporters you'll see that almost all use poly straps and ratchets.
reddogg
Re: Tie Down Straps
« Reply #4 on: August 02, 2011, 09:19:31 PM »
you should be able to pick some up at a local flea market or the like. Just need to look them over good. I picked up a heavy 20' tow chain for $15 at a yard sale. check out the goodwill stores too, I just got a set of Victor Brand Torches( not the chinese nockoffs) for $75 at Goodwill.
Re: Tie Down Straps
« Reply #5 on: August 02, 2011, 11:15:45 PM »
Large ratchet straps for tying down your trailer are fine tiedown the axles and not the frame and yes cross the straps.
Re: Tie Down Straps
« Reply #6 on: August 02, 2011, 11:19:09 PM »
2" ratchet straps from a Farm Supply store are plenty.
