Author Topic: Risky for a dana 35? youtube clip  (Read 1642 times)
« on: August 19, 2011, 07:19:45 PM »
I dont know what he did to beef his up, but I'm pretty sure mine would break. Oh, and i think his snorkel looks stupid, although it wont be injesting water anytime soon.
<a href="http://www.youtube.com/v/O1_kbu3iRj4" target="_blank" rel="noopener noreferrer" class="bbc_link bbc_flash_disabled new_win">http://www.youtube.com/v/O1_kbu3iRj4</a>
« Last Edit: August 20, 2011, 12:30:27 PM by Jeffy »
Re: Risky for a dana 35? youtube clip
« Reply #1 on: August 19, 2011, 07:24:13 PM »
I got that same tube bumper.  Its only rated at 200lbs tongue weight not sure what the pull weight is but it would be much lower than what he is trying to pull.
« Reply #2 on: August 19, 2011, 07:46:13 PM »
when it starts hopping thats when your break stuff
« Reply #3 on: August 20, 2011, 12:29:55 PM »
It's got axle wrap for sure.  Both sides have traction evenly so other then the leafs springing back and forth, it's not beating it up too bad.  If he was open, he'd probably break the spider gears but he's got a truetrac.  He's also for alloy axle shafts so the splines are much stronger.  Honestly though, the axle wrap is probably helping him not break anything.
The problem with those tube bumpers is that they don't mount directly to the crossmember.  Typically you have three sets of holes on the bumper and two on the bracket.  This allows you to have the bumper mounted 1" lower so you can clear your rear tire.  Problem is if there is any leverage on the bumper the offset will allow the bumper to ply itself off the rear crossmember, in either pulling or getting rear-ended.  I've had two of those bumpers and and no bumperless till I find something more suitable.
