Author Topic: Tire carrier/swing arm opinions  (Read 3987 times)
« on: September 03, 2011, 09:24:01 AM »
When i get home ill be looking to get a tire carrier/swing arm to replace the stock carrier. Ive got my 33" spare on the stock one and i noticed it's started to stress the tailgate. Id like a swing arm set up but i want a real good one, with a simple, but good latch (dont want to have to be pulling pins, flipping levers and turning knobs just to open my damn tailgate), and i dont want it to rattle much if at all. Any suggestions? Id be open to swapping out the rear bumper too, if the carrier is sold as a combo or whatever.
Re: Tire carrier/swing arm opinions
« Reply #1 on: September 03, 2011, 12:08:54 PM »
I like the Rock Hard rear bumper tire swing that the previous owner through on mine. It's realy smooth to operate and not too pricey.
http://www.rockhard4x4.com/default.asp
« Reply #2 on: September 03, 2011, 12:14:50 PM »
there is meany different designs but mainly for what you want is the flip style latch other then that just pay attentions to weight ratings to make sure it's supports everything you want off it.
if you are good a fabricating you could build one your self with a kit like I did
http://www.emsoffroad.com/store/index.php?main_page=index&cPath=78
http://www.atozfabrication.com/store/Tire-Carrier-Swingout-Heavy-Duty-Hinge-Kit.html
« Last Edit: September 03, 2011, 12:15:25 PM by Torch_Ind »
« Reply #3 on: September 04, 2011, 02:07:14 AM »
the rock hard one seems pretty sturdy (it better be for 700 bucks lol). Are there any that attach to your stock bumper that are of good quality?
« Reply #4 on: September 04, 2011, 09:14:46 AM »
There's always a body mounted swing out as an option. Bestops holds up to a 35" for 300. Not sure how well people like them though.
http://www.jeep4x4center.com/oversize-tire-carrier-highrock-4x4-bestop-61960-01.html
« Last Edit: September 04, 2011, 09:16:07 AM by 1995yj »
« Reply #5 on: September 04, 2011, 09:34:32 AM »
i have one of those, it's not bad but not great either, if i'd start again i would go with a heavy duty bumper mounted one rather than the bestop
it's a big improvement over the tailgate only solution but it still rattles (and i have the big TJ hinges as well, with the stock YJ hinges was quite bad even with the bestop tire carrier).
i have 33x12.5x15 wheels
« Reply #6 on: September 04, 2011, 10:32:38 AM »
I'm really happy with my built one I opted for the heavier spindle when I purchased from a-to-z fab.. I cheeped out on the latch and I used big bolts that we had laying around the shop.. the spin out bolt works good for me it's that big of deal to open and close.  also no chance of rattle cause it's basically bolted with the t handle I built and if it does you can put a bar on it and give it the little extra but I haven't had to.. no rattles at all
« Reply #7 on: September 04, 2011, 03:48:44 PM »
There's ORFab's swing out as well as T&T Custom.  I like the T&T but not the price.
http://www.orfab.com/details.php?Application=Jeep&Part_Number=86201
http://www.tntcustoms.com/tjljreartirecarrier.aspx
« Reply #8 on: September 04, 2011, 04:02:06 PM »
there body mount style but they are nice
Tom95YJ
« Reply #9 on: September 04, 2011, 08:18:45 PM »
I had a friend of mine fab up a tire carrier for my YJ using A-Z fab's kit.  It was a great bumper the only dislike  I had was the Threaded latch.  It always seemed to strip out
« Reply #10 on: September 04, 2011, 09:12:32 PM »
couldn't have been that heavy of a bolt.
« Reply #11 on: September 04, 2011, 10:22:52 PM »
For a latch use a de staco latch and mount at an angle so it draws the carrier in and down, that will eliminate rattling
« Reply #12 on: September 06, 2011, 12:30:03 AM »
wonder if it will be as strong with it hanging from the stock hinges.
« Reply #13 on: September 06, 2011, 11:19:39 AM »
Both use their own hinges and backing plates.  I know the T&T can also be welded to corner guards instead.
