Author Topic: Bent Rear Axle  (Read 10144 times)
Re: Bent Rear Axle
« Reply #15 on: September 10, 2011, 01:20:35 PM »
That is how the bearing looks, it's a set 10 bearing and that ring holds the bearing together
Yup, it's a better design.  That's how mine were as well.
Re: Bent Rear Axle
« Reply #16 on: September 10, 2011, 07:41:24 PM »
Pressed on the new bearings (f***ing scary on a harbor freight 12 ton press.) Everything was cake, except the emergency brake shoes. Went to put on the wheel, and the wheel studs are too short - only catching a few threads through the crappy look-at-my-microscopic-penis god-awful bling-blingin' wheels. The wheel studs are threaded. Could only find Alloy USA selling what I need. They are 1/2" dia. 20 pitch 1-1/2" long, Alloy USA sells 1.5" and 2.0". Ordered 12 up (2 spares) from Summit for $2.95ea; should be here Wednesday. They listed for 4.99ea, but I spoke with Dakota in SummitRacing sales, and he was able to match some other random online competitor I found in Google.
For now, I finished putting on the new axles with the suicide length wheel studs. It'll stay parked until I'm all done next weekend.
Here are some photos and the wheel studs. Will take a photo of the 1.5" wheel studs next weekend to show you how short they are.
Ha! Race fell out in my hand. Didn't get as lucky on the other side, but the bearing puller was unnecessary - going back to Harbor Freight.
Here's the bolt I need for my crap-tastic alloy wheels:
Brand  Alloy USA
Manufacturer's Part Number  99STUD2
Part Type  Wheel Studs
Product Line  Alloy USA Wheel Studs
Summit Racing Part Number  ALY-99STUD2
UPC  804314215361
Wheel Stud Style  Screw-in
Wheel Stud Thread Size  1/2-20 in. RH
Underhead Length (in)  2.000 in.
Quick-Start Nose  No
Quantity  Sold individually.
« Last Edit: September 10, 2011, 07:43:05 PM by 1995yj »
Re: Bent Rear Axle
« Reply #17 on: September 10, 2011, 07:58:34 PM »
The race just fell out?  They should be a little snug in the holes but not pressed in by any means.
Re: Bent Rear Axle
« Reply #18 on: September 10, 2011, 08:00:06 PM »
Probably not a good sign, huh?  :lol: I used a cheap seal puller and a small hammer on the other race.
« Last Edit: September 10, 2011, 08:01:10 PM by 1995yj »
Re: Bent Rear Axle
« Reply #19 on: September 10, 2011, 08:41:25 PM »
Was it the bad side?  What you have to worry about is the bearing seizing up then honing out the hole.
Re: Bent Rear Axle
« Reply #20 on: September 10, 2011, 08:45:30 PM »
The driver side race fell out.  That bearing looked like it was ready to come off the inner/shaft race - all sloppy. The passenger side race - bent axle - had to be tapped out. That bearing seemed to be ok.
Re: Bent Rear Axle
« Reply #21 on: September 10, 2011, 09:30:03 PM »
Did you look at the race and the hole?  Usually you'll see signs of scratches going around the outer part of the race if it was spinning.  If there were none then I wouldn't worry about it too much.  It could have caught on the rollers and popped out with it.
Re: Bent Rear Axle
« Reply #22 on: September 10, 2011, 09:32:23 PM »
how long were the stock studs? I assume they were fine since you've been using these wheels before - if that's the case you should call the store you bought the axles from and let them know.
Re: Bent Rear Axle
« Reply #23 on: September 10, 2011, 11:13:00 PM »
The tube looked perfect.  It was probably the later of the two - I had tapped the axle with a mallet to work it out.
It looked like the lugnuts grabbed about a 1/2" prior - I hadn't checked previously, since I haven't had the occastion to. I already made a review on 4wheelparts and planned on calling the sales guy on Monday.
Re: Bent Rear Axle
« Reply #24 on: September 13, 2011, 12:06:34 AM »
FYI the stock bearings race are made to break on install. (Its normal) it allows the race to stay aligned with the bearing when you press it on.
My 44 has the same loose driver side race issue. They dont fit real tight, since they use a retainer flange to hold them in..
Re: Bent Rear Axle
« Reply #25 on: September 13, 2011, 01:35:26 AM »
what do you mean break?
Re: Bent Rear Axle
« Reply #26 on: September 13, 2011, 10:29:54 PM »
One side of the bearing outer race has a ring that keeps the new race and the core together, once tightened in the ring shears off and acts as a spacer and the outer race floats. (Mine is that way anyhow and so was my other 44...)
Mine is a 1987 Cherokee limited axle, if that makes a difference..
Re: Bent Rear Axle
« Reply #27 on: September 17, 2011, 04:32:47 PM »
Well, just spent half the day removing both axles, switching the wheel studs, and reinstalling. Took a quick test trip, everything seems good. Time for some PBR :beers:
Dave, one of my bearings had done exactly as you said. The race stayed in the housing upon removal of one of the shafts.
Here's the photos of the supplied 1/2" dia. 20pitch 1-1/2" length wheel studs next to the 1/2" dia. 20pitch 2" length wheel studs by Alloy USA.
Forgot the flash, but that extra 1/2" makes a world of difference.
Re: Bent Rear Axle
« Reply #28 on: September 17, 2011, 06:13:07 PM »
Wow, those are some tiny studs.  Glad you got it all back together.
Re: Bent Rear Axle
« Reply #29 on: September 18, 2011, 10:06:33 AM »
+1 I want to see if this actually fixes your problem!  are you going to try it with the same rims and tires you did before?
