Author Topic: TJ seat swap  (Read 2035 times)
Nicks92jeeper
TJ seat swap
« on: September 11, 2011, 12:36:20 AM »
I have been looking around and can't find any concrete information on what seats can be swapped into a TJ (2000) Does anyone know what would fit in there with direct bolt fit? You can find plenty of info for yj but I can't find anything on the TJ. Any help would be appreciated.
Re: TJ seat swap
« Reply #1 on: September 11, 2011, 09:11:17 AM »
Seats are pretty easy to mount but there are some things to be aware of.  First sous be the overall width.  If you have a console hen this could be a problem.  For the mount, there are. Metal plates on the corner of the seat.  Measure the distance between them and compare.  You can always drill a new hole on the plates or else make adapters to match the seat base.
If you ro with racing seats, be aware that the seat bolster might raise the front of the seat higher then stock.  This can make getting in and out a PITA.  You can lower the seat by getting some Corbeu mounts or by removing the sliders.
For a TJ, I'd consider +2003 seats.  These are the nicer ones with the headrests and wider back.  Easy to install with no modifications required.
