Author Topic: Has anyone changed to a different camshaft?  (Read 28576 times)
Re: Has anyone changed to a different camshaft?
« Reply #15 on: September 21, 2011, 08:44:30 AM »
Found another Cam but zip for Specs.
Sealed Power CS 779 its for the  jeep 2.5 but what would we gain by using it.
OEM specs, there's a list of cam specs somewhere on their site - i looked at the same one abou 1 year ago, stock replacement
« Reply #16 on: September 21, 2011, 05:28:48 PM »
There site listed nothing but for the cost thats what I thought it was stock.  I was hoping.
« Reply #17 on: September 21, 2011, 06:42:41 PM »
Found some more info, will see if they still sell thses parts.
Quote
I have been looking into more power from my 2.5 other than supercharger or turbo..so i have SOMTHING from comp cams.. here is the e-mail
Hi Brian,
You will want to use part# 822-12 lifters with this camshaft and also use part# 926-12 valve springs which will require some machine work to the head to fit. I will list pricing below for you, if you have any further questions or need help ordering you can do so direct through me. Please get back with me if I can help further, thanks.
114-000-5: $198.40
822-12: $66.41
926-12: $66.68
PRICES ARE SUBJECT TO CHANGE IF ORDERED IN A KIT
For more information about any other COMP CAMS product, please feel free to contact COMP CAMS at 1-800-999-0853 or at www.compcams.com
Thank you for choosing COMP CAMS
-----Original Message-----
From: Brian Reichard [mailto:twistedoffroad1997@yahoo.com]
Sent: Friday, January 15, 2010 10:38 PM
To: Cole Ventrone
Subject: Re: brian reichard - COMPCams.com - Camshaft Recommendation Form
To: twistedoffroad1997@yahoo.com
Sent: Fri, January 15, 2010 1:26:14 PM
Subject: RE: brian reichard - COMPCams.com - Camshaft Recommendation Form
Hi Brian,
After looking through your information I suggest one of our CUSTOM GRIND
series cams. Here is the part number for the cam I have suggested
(114-000-5). I recommend that you change your valve springs and lifters if
you are interested we here at Comp Cams can put kits together. Just let me
know?  I will list the specs on this cam below. If you have any questions
feel free to reply or call our tech line. Have a great day.
GRIND#: A4 5226 /5206  H 113.0
                             DURATION @ .050 INTAKE      200  ROCKER ARM
RATIO
VALVE ADJ INTAKE      .000  DURATION @ .050 EXHAUST    206    INTAKE
1.60
VALVE ADJ EXHAUST    .000  LOBE LIFT INTAKE            .2600  EXHAUST
1.60
VALVE LIFT INTAKE    .416  LOBE LIFT EXHAUST          .2720
VALVE LIFT EXHAUST    .435  LOBE SEPARATION          113.0
DURATION              .006  INTAKE C/L                110.0
TAPPET LIFT INTAKE    248  CAM ADVANCE                3
TAPPET LIFT EXHAUST    255  HYDRAULIC                Y
VALVE TIMING          .050  OVERHEAD CAM            N
VALVE OPEN INTAKE      10-  JOURNAL DIAMETER        STD
VALVE OPEN EXHAUST      39
VALVE CLOSED INTAKE    30
VALVE CLOSED EXHAUST    13-
<outbind://49/www.compcams.com>
Cole Ventrone
Comp Cams Performance Group
ZEX, RHS, FAST, INGLESE,
cventrone@compcams.com <mailto:msummerfield@compcams.com>
1-800-365-9145 ext. 534
Sent: Monday, January 11, 2010 9:12 AM
To: Cole Ventrone
Subject: brian reichard - COMPCams.com - Camshaft Recommendation Form
<http://www.CompCams.com>
Camshaft Recommendation Request
Note To Customer: The information below has been received by CAM Help? tech
support. This email is for your records.
CONTACT INFORMATION
First Name:    brian    Email:    twistedoffroad1997@yahoo.com
Last Name:    reichard    Day Phone: (8am-5pm CST)
VEHICLE INFORMATION
Make:    jeep    Model:    wrangler
Year:    1997
Weight:    2000 lbs.    Axle Ratio:    4.11
Transmission Type:    Automatic    Tire Height:    31x10.50x15
Torque Converter Stall Speed:    none
ENGINE INFORMATION
Engine Block Type:    Other    Engine Size:    150ci 2464cc ***
Number of Cylinders:    4    Bore:    3.88
Stroke:    3.19    Compression Ratio:    9..2:1
Piston Type:    n/a    Connecting Rod Length:    n/a
Intake Manifold Type:    n/a
Cylinder Head(s) Brand:    403
Head Runner Volume:    n/a    Ported Heads:    No
Intake Valve Size:     n/a    Exhaust Valve Size:    n/a
Rocker Arm Type:    Stock    Rocker Arm Ratio    n/a:1
Timing Set Type:    Chain    Timing Set Fixed/Adjustable:    Fixed
Exhaust Headers:    No    Exhaust Type:    Single
RPM Range Low:    N/A    RPM Range High:    5550
Nitrous Oxide:    No    Horsepower from Nitrous:    N/A
COMPUTER CONTROLLED VEHICLES
Vehicle Computer Type:    Stock
Speed Density Sensor:    Don't Know
Mass Air Sensor:    Don't Know
FUEL DELIVERY
Fuel Type:    Pump Gas    Fuel Octane Rating:    97
Carburetor:    No    Carburetor Size:    N/A
Direct Port Injection:    No    Number of Injectors:    N/A
Oversize Injectors:    N/A
Electronic Fuel Injection:    Yes    Oversize Injectors:    No
Custom Tuned:    No
AIR DELIVERY
Turbo Charger:    No    Supercharger:    No
Max Boost Level:    n/a
APPLICATION SPECIFICS
Application Type:    Off-Road 4x4    Other Application Type:    N/A
Race Class (If Applicable):    N/A
VALVE TRAIN SPECIFICS
Desired Lifter Type:    Not Sure
What type of camshaft are you currently using?
Camshaft Brand:    stock    Part Number:    N/A
Specs:    N/A
Read more: http://forums.jpmagazine.com/70/8007538/jeep-engine/25-cam-and-performance-2-comp-cam-info/index.html#ixzz1YdaRkiJQ
« Reply #18 on: September 21, 2011, 07:07:49 PM »
I left a message on their forum to see what they say about a cam or kit for the 2.5.
« Reply #19 on: September 21, 2011, 07:39:38 PM »
I also subbmitted a request for cam recommendation thru their web site.
« Reply #20 on: September 21, 2011, 08:06:51 PM »
yeah, it took me a while to find it, there's a product catalog pdf that lists the specs for their cam. I did get itchy too when i saw it but nothing there.
Offline andpgud
« Reply #21 on: September 22, 2011, 02:56:37 AM »
is 140$ a good price for a camshaft that give me more power on the 2k-4k or should I just save the money and spend it on a 4 liter swap?
« Reply #22 on: September 22, 2011, 12:36:19 PM »
sharp how much improvement on the Hesco inc. link he posted
Advertised duration: 264        214@ .050
Lobe centers: 110 degrees
Lift: 470
@ 289$
would it be worth the cash plus add the valves and springs
Offline andpgud
« Reply #23 on: September 22, 2011, 01:38:26 PM »
Are you answering me or someone else?
What lifters and tickers should I get with it?
« Reply #24 on: September 22, 2011, 03:38:33 PM »
Funny, that guy posted the same post all over the internet.  If you look on Jeepz, you'll find Bounty as well as jfrabat and Sine Deviance's Avatar commented.  Interesting how it's listed as an AMC 1980-1983 cam which wouldn't be an AMC but rather a Pontiac.
http://www.jeepz.com/forum/cj-yj-tj-jk/28507-2-5-cam-performance-comp-cam-info.html#post224772
Offline andpgud
« Reply #25 on: September 22, 2011, 04:54:09 PM »
So for the cam I can get. Should I go with the mopar springs?
« Reply #26 on: September 22, 2011, 08:58:00 PM »
Lift: 470
 (at)  289$
i have no idea but if i am to guess probably about 15HP and possibly 20 to 25 if you get roller rockers 1.6 or 1.7 respectively. Mind you it also depends to what that cam's range is and i'm too lazy to look right now, it could get better and flatter torque distribution rather than top end so that can be more beneficial even with less HP increase. They have pretty good customer service so an email or phone call will probably get you the right answer.
« Reply #27 on: September 23, 2011, 06:21:21 PM »
Just got a reply from Crane Cams.
Quote
Hello,
We do not make cams for that engine. We may be able to regrind a
suitable core. The cost would be $126.00 plus shipping.
Thanks for asking,
    Greg
« Reply #28 on: September 23, 2011, 06:48:28 PM »
they used to from what i remember, i guess they just do the 6 cyl now.
« Reply #29 on: September 23, 2011, 07:21:34 PM »
What do they do when they re-grind a cam? Add material to get a certain lift/duration?
