Author Topic: running hot after changeing heater hose  (Read 5636 times)
Re: running hot after changeing heater hose
« Reply #15 on: October 08, 2011, 06:06:59 PM »
I have the 195 in there now,  and no i did not see any movement in the radiator I though it could be the water pump so i pulled the water pump off but it look like new to me. I never replaced the water pump just pulled it off all i replaced was the thermostat.
Which way did the spring face.  Into the Block or into the housing.
« Reply #16 on: October 08, 2011, 07:39:47 PM »
did you put the side with the spring towards the cylinder head (away from the hose side)?
« Reply #17 on: October 08, 2011, 07:59:41 PM »
Is the pump a reverse flow?
« Reply #18 on: October 08, 2011, 09:42:33 PM »
Just one more question.  What color is the coolant you are using now and what was the color before.
countrymusic1993
« Reply #19 on: October 09, 2011, 06:25:56 AM »
the spring is facing to the block it only fit in one way, the pump should be regular flow I think it is the original and it was working fine before, finally the coolant now is green and the coolant that came out was brown but was originally green.
Nicks92jeeper
« Reply #20 on: October 09, 2011, 08:24:09 AM »
Did you by chance reverse the hoses connection if you changed both?
« Reply #21 on: October 09, 2011, 09:17:49 AM »
have someone in the car watching the gauge while you keep your hand on the upper hose, when the thermostat opens it will get pretty warm quick so give a signal and the other person read the gauge - your goal here is to see if your gauge shows 260 when the thermostat opens, if that's the case then it's either the thermostat or the gauge/sender. A more unconventional way is to leave the cap out (when the coolant is cold, don't take it off when hot - i'm sure you know but i just mentioned it to be safe) - if it starts boiling before the thermostat opens then that's the problem, if not then it's your gauge or sender.
countrymusic1993
« Reply #22 on: October 09, 2011, 09:43:07 AM »
I only changed one hose and I should put my hand on the upper radiator hose right.
« Reply #23 on: October 09, 2011, 01:41:12 PM »
It will start to overflow a little before the thermostat opens.  So you'll want to catch the overflow and add some once the thermostat opens.
I'm still wondering if he got the right water pump though.
countrymusic1993
« Reply #24 on: October 09, 2011, 04:17:35 PM »
the water pump I took off was the original so unless the factory put the wrong one on it is fine and I just ordered a new pump i figured i would replace it while it is off since it has over 100k on it so i cant do anything until it comes in.  another question though do you have to put any sealer on the inlet pipe or do you just screw it in.
Nicks92jeeper
« Reply #25 on: October 10, 2011, 12:23:03 AM »
What about air in the system? In my Honda if there is air in the system it idles funny and does weird things.
knotts89
« Reply #26 on: October 10, 2011, 12:16:36 PM »
Might want to try and put the same size hose back on it
