Author Topic: Alt Question  (Read 4490 times)
Re: Alt Question
« Reply #15 on: December 06, 2011, 02:15:24 PM »
Mine shows a drop in voltage when put in reverse but it seems to be OK at the battery.
Re: Alt Question
« Reply #16 on: December 06, 2011, 03:26:12 PM »
Hmm, mine actually holds at around 14v.  Although I know it's not that accurate.  My 2M radio has a volt meter built into it so I can double check it at start-up.  The stock gauge is pretty cheap though.  It comes out easy enough.  I'd like to eventually change out all of my gauges for aftermarket sealed units.  If your Jeep has a cowl leak, it usually leaks into the back of all the gauges which causes them to be inaccurate over time.
Re: Alt Question
« Reply #17 on: December 06, 2011, 08:08:17 PM »
my voltage gauge goes up and down with the blinkers... I'm not too trusting of it.
Noticed that tonight.  Did not drop as low as I thought cause the gauge only goes down to 9 V.  and it did not go that low   More like 10.5 was as low as it got.
Need to look my fog lights up cause they sure do put a draw on the system.
Here is what I got for fog Lights they should not put that much strain on it.
Quote
H3 12V 35W Xenon HID Conversion Kit 3000K
« Last Edit: December 06, 2011, 08:12:30 PM by grumpygy »
