Author Topic: Taillights  (Read 5357 times)
Offline grumpygy
Taillights
« on: December 21, 2011, 06:14:52 PM »
  Who has changed over to LED.  Just ordered a set made by Rampage.  My old drivers side was looking bad must have backed into something cause the side marker was gone.  Also starting to have problems with Corrosion turn signals work part of the time.  Mostly work when I'm not moving and just checking to see if they work.  But on the road Not so much.
  Hope these have better light.
Torch_Ind
Re: Taillights
« Reply #1 on: December 21, 2011, 08:59:17 PM »
Re: Taillights
« Reply #2 on: December 21, 2011, 10:01:55 PM »
Offline grumpygy
Re: Taillights
« Reply #3 on: December 23, 2011, 10:15:05 PM »
These are the ones I got.
I will mount a set of these to them.
Already have them mounted to the old housings and its great having light to back up to.
« Last Edit: December 23, 2011, 10:20:30 PM by grumpygy »
b.hog
Re: Taillights
« Reply #4 on: December 25, 2011, 09:51:49 AM »
Ive got those tail lights.I painted the chrome black tho to match all the black on my jeep.They're alot brighter then stock,I really like them.
Offline grumpygy
Re: Taillights
« Reply #5 on: December 28, 2011, 01:14:40 PM »
Got them in will try to put them on tonight and take Pictures.  But so far am Impressed with the Housings Metal where the stock one is plastic and part of the reason I'm changing mine cause the housing is cracked and broken.
Re: Taillights
« Reply #6 on: December 28, 2011, 01:34:21 PM »
i like them just not the chrome part, painted black would look nice but that's just a matter of personal preference. so is the chromed part of the lens also metal or just the housing.
Re: Taillights
« Reply #7 on: December 28, 2011, 02:25:44 PM »
Doesn't look like any of it is metal.  That's a stock housing that's been 'chromed' with a fancy lens.
Re: Taillights
« Reply #8 on: December 28, 2011, 04:48:15 PM »
I have to say, I really enjoyed these on my YJ as reverse assist lights. KC 26 Series
http://www.kchilites.com/lights/26-series/2x6-long-range-black
« Last Edit: December 28, 2011, 04:50:51 PM by 1995yj »
Offline grumpygy
Re: Taillights
« Reply #9 on: December 28, 2011, 06:54:58 PM »
  All metal and its not the same housing as I'm replacing.  But will not do it today.  The rain is making up for lost time.
Offline grumpygy
Re: Taillights
« Reply #10 on: January 01, 2012, 07:23:07 PM »
Just drilled them to add the spot lights they are all metal.
Re: Taillights
« Reply #11 on: January 01, 2012, 07:41:58 PM »
if you added them on top of the housing you should seal the bolt/bracket to the housing otherwise water will make it in there.
Offline grumpygy
Re: Taillights
« Reply #12 on: January 01, 2012, 10:29:49 PM »
Mounted to the side, wires barely fit in the grommets I used so that is a tight fit and the mounting bolt hole should not be a Problem.  Really like the gasket this uses for the lens cover.   Changed mine mostly cause their was moss starting to grow in the old housing.
Offline grumpygy
Re: Taillights
« Reply #13 on: January 02, 2012, 05:26:29 PM »
Well there are now on.
« Last Edit: January 02, 2012, 05:27:08 PM by grumpygy »
Re: Taillights
« Reply #14 on: January 02, 2012, 07:17:10 PM »
looks good, does the tailgate clear the spot light?
