Author Topic: engine temp. problem  (Read 1769 times)
robertsiii
« on: December 21, 2011, 09:26:08 PM »
my temp. keeps rising from180 to 230 holds there for awhile then falls back to 180  . I recently replaced my water pump with a flow kooler pump ,new therm. housing .new robertson  stat. new radiator cap ,new hoses  flushed radiator . thought it was air locked . ive blead the heater coil and lines. still doing it .it not red lineing . this happens at speeds of 55 to70. any ideas?
Re: engine temp. problem
« Reply #1 on: December 21, 2011, 10:04:05 PM »
Your thermostat is stuck closed.  When it hits 230, the pressure blows the thermostat open then it cools and starts over again.
« Reply #2 on: December 21, 2011, 10:54:30 PM »
bad thermostat (opens too high) or bad gauge or sender (shows 230 at 200 for example).
robertsiii
« Reply #3 on: December 22, 2011, 06:48:35 AM »
 thats what i figured, stat opened fine in pot of boiling water . ill try a diffent stat. thanks.
« Reply #4 on: December 22, 2011, 08:56:21 AM »
Not to be captain obvious or anything, but, make sure you have it in the right direction. It would exhibit similar behavior backwards.
robertsiii
« Reply #5 on: December 22, 2011, 05:50:03 PM »
installed new stat.today, all is well .temps running normal.  :thumb:  merry christmas and happy new year to all !!!!!
