Author Topic: Hand throttle  (Read 1351 times)
  • 4BangerJP.com® Donator
Hand throttle
« on: December 28, 2011, 09:40:59 AM »
For you guys using hand throttles mounted on your manual stick/auto do you have any problems with the engine rpm when shifting gears?
Guess you'd just leave enough cable to accomodate gear change motion, right?
« Last Edit: December 28, 2011, 09:46:59 AM by chrisfranklin »
Re: Hand throttle
« Reply #1 on: December 28, 2011, 10:59:00 AM »
Just make sure your route the cable with enough slack and you will be fine.
Re: Hand throttle
« Reply #2 on: January 03, 2012, 08:52:17 AM »
I have no problems with mine, and I run a hand throttle AND a cruise control...
