Author Topic: efan control  (Read 1792 times)
Offline brokenwrist21
efan control
« on: January 13, 2012, 01:51:23 AM »
hey yall i just got my taurus 3.8 fan and now i need to get the controller for it. i know this has been covered about a thousand different times. who uses what controller, the only time the temp will get high enough for the fan to run, is during parades, while wheeling, sitting in traffic, driving through town, etc. i would like to have the ability to run it manually if need be
  • Poseur ExtraordinaireŽ
Re: efan control
« Reply #1 on: January 13, 2012, 03:03:01 AM »
Re: efan control
« Reply #2 on: January 13, 2012, 11:58:27 AM »
  • Chief Squirrel BlowerŽ
Re: efan control
« Reply #3 on: January 13, 2012, 01:46:25 PM »
my install
http://4bangerjp.com/forums/index.php/topic,10360.0.html
Hayden adjustable controller can be had for about $30 on Amazon, i used a threaded probe but the exact same controller is available with a "thru fins" probe as well. "Always Off" can be controlled by the "ignition on" wire at the controller, "Always On" can be controlled by the A/C compressor on wire at the controller as well so you can add an On/Off/On DPDT switch to control these 3 states (auto, always on, always off) - i am planning to do that but not completed yet.
Re: efan control
« Reply #4 on: January 15, 2012, 11:48:48 PM »
thanks guys, i think i'm wire mine like jeffy did. it looks the simplest.
