Author Topic: Clutch pedal adjustment?  (Read 1270 times)
« on: January 29, 2012, 04:49:11 PM »
Is there any way to adjust the clutch pedal?  I just fixed the hydraulic system, but, for a while (before the swap), I find the that clutch pedal has to go ALL the way in for the clutch to disengage, and I feel it should be a little higher up.  Besides, the pedal has about 1" of slack now, and it vibrates... Is there a way to adjust it so that the pedal will work higher up (to lose that slack)?
Re: Clutch pedal adjustment?
« Reply #1 on: January 29, 2012, 05:27:24 PM »
check this tread http://4bangerjp.com/forums/index.php/topic,10469.msg91576.html#msg91576
could be what you're missing
there's no adjustment (it auto-adjusts under normal circumstances)
