Author Topic: Back on the road!  (Read 4255 times)
SDWE61988
Back on the road!
« on: March 06, 2012, 01:57:39 PM »
After 4 months down, my Jeep is back on the road!  :weee:  Back in October/November I was troubleshooting a knocking noise in my engine on the work bench page.  It turned out to be a cracked # 2 piston.  I was seriously thinking about selling it, but I could not bear to let it go for peanuts.  I then looked at upgrades.  I really wanted to do a v8 upgrade or an I6 swap, but it was a lot more then I could afford and there was too many uncertainties.  I just could not justify the expense.  I ended up pulling the engine, having the block bored out, the head machined and performed a full rebuild.  My brother came down (he is a CJDR dealer mechanic in NH) and helped out.  I got a little OCD and painted up the external enigne components.  The rebuild went relativly smooth with a couple exceptions from mistakes I did during disassembly and cleaning.  I have some pics and as soon as I can I will post them or a link to them.  Thanks for everyone's help on here with the troubleshooting.  I am not sure if this is the right page, but I just wanted to  post something!
Re: Back on the road!
« Reply #1 on: March 06, 2012, 04:10:03 PM »
looking forward to the pics
how's it running now with the fresh rebuild?
« Reply #2 on: March 06, 2012, 10:14:03 PM »
I second ^ that!
Glad to here you stuck it out.
« Last Edit: March 06, 2012, 10:14:30 PM by 1995yj »
SDWE61988
« Reply #3 on: March 07, 2012, 06:14:07 AM »
She runs good.  It feels like it might have a little more torque on the hills (that could be my imagination).  I still have to downshift on some of them.  It is still breaking in so time will tell.  The gas milage on the 1st tank of gas sucked big time. i think it was about 13-14 mpg.  I think (hope) it will get better as she gets broken in.  I was averaging around 19 before all this.  I still need to do a couple things to it.  I had an oil pan (off of a yj engine) engine all cleaned up and painted ready to go, to find out, it won't fit on the tj block with the tj oil pickup.  I plan on pulling the pan off when I do the first oil change (probably next weekend) and cleaning it up and painting it.  I bought a skid plate for the engine that I will install then also.  I am still working on the pics.
SDWE61988
« Reply #4 on: March 10, 2012, 03:42:40 PM »
Ok lets see if this works.  This link should take you to the set of pics on my flicker page.   there are 30 photos there. I do not think I would be able to load them all.  Let me know if this does not work.
 http://www.flickr.com/photos/40191372@N03/sets/72157629556004039/
« Reply #5 on: March 10, 2012, 03:52:45 PM »
I was able to view but it was a small pain to get in.
  For some reason they also said the photo's were not safe, Like in a porn warning.  Not sure what that was about cause all I seen of a person was a hand. :slapfight:
SDWE61988
« Reply #6 on: March 10, 2012, 04:08:16 PM »
I guess it was 4 clylinder jeep porn!  :smokes:  I will look into it.
SDWE61988
« Reply #7 on: March 10, 2012, 04:17:21 PM »
Ok I went in and set the safety setting on those photos to safe, so you should no longer get the warnings for those photos.  Maybe I will try to also post in the readers rides section.
« Reply #8 on: March 10, 2012, 05:02:48 PM »
No problems with the pics here.
« Reply #9 on: March 10, 2012, 08:01:17 PM »
I dont like how that engine looks.  It's just TOO clean.  You need to get some mud and dirt in there, so I suggest you take it wheeling!  Nice job, man!  I've been wanting to do that to mine for a while, but just have not found a chance!
Offline Tr00b
« Reply #10 on: March 11, 2012, 07:26:27 AM »
That's bad ass! I love the color. Hope that gas mileage comes back.
Did you have any work done to the head before you put it back on?
« Reply #11 on: March 11, 2012, 02:05:34 PM »
Good job man!
SDWE61988
« Reply #12 on: March 12, 2012, 06:00:37 AM »
Thanks for the compliments.
The head was cleaned magnafluxed and the mating surfaces machined, and the valve guides were redone  I did not have the ports polished.  The machine shop I used said it really would not do anything for the rebuild I did.  The shop does a lot of local drag cars so they were pretty knowledgeable.  They probably thought I was crazy to even rebuild it.  The gas milage is making it way back up now.  Hopefully after I change the oil back to synthetic this coming weekend it will be back to normal.
SDWE61988
« Reply #13 on: March 12, 2012, 06:04:28 AM »
Hopefully I will be able to hook up with a club this spring and maybe i can try out Rouch Creek.  Unfortunatly there is nothing close in the people's communist republic of MD.
« Reply #14 on: March 12, 2012, 02:03:43 PM »
Dont change to synthetic till you have done a lot of miles,
I did on my 2.5 rebuild at 2000 miles and it blew the ring seating.. Compression
dropped to 135 ,,
Drained and ran dino for 3 oil changes and got my compression back. (165+)
The 2.5 has a surprisingly hard block. Takes a while to break in the cylinders.
My builder commented on it as well , we bored it 50 and he said he had to
rotate the tool head several times. Said it was like doing a high nickel chevy block...
