Author Topic: Ignition/Fuel cutofff switch  (Read 2346 times)
Offline lokitim
« on: March 06, 2012, 02:11:55 PM »
How do you go about hooking up a cutoff switch, to prevent theft, for the ignition or fuel?
1993 YJ, 4cyl, AX15 5spd,  J20 3/4 ton axles, SOA with stock springs, disc brakes on all fours, hi-steer, flat tops,33x12.50 General Grabbers on beadlocks,Warn Front Bumper, Smittybilt w/swing away tire mount rear bumper, custom Hi-Lift Mount, Bedliner interior & body sides, Flush mount tail/backups
Re: Ignition/Fuel cutofff switch
« Reply #1 on: March 06, 2012, 02:50:02 PM »
ASD relay imo, cuts both ignition and fuel
Offline lokitim
« Reply #2 on: March 06, 2012, 03:50:25 PM »
And how do I go about  doing this?
« Reply #3 on: March 06, 2012, 04:10:32 PM »
what year/model Jeep?
« Last Edit: March 06, 2012, 05:04:31 PM by sharpxmen »
Offline lokitim
« Reply #4 on: March 06, 2012, 04:41:18 PM »
93 yj
« Reply #5 on: March 06, 2012, 05:04:20 PM »
In general:
1) Locate the ASD relay
2) Find the wires that feed 12 volts to it.
3) Cut a wire
4) Put a switch in line
« Reply #6 on: March 06, 2012, 05:04:45 PM »
93 yj
if it's a YJ you'd need to cut the +12v power side going to the coil of the ASD relay and connect you alarm/immobilizer cutoff relay in there. What that would do is similar to taking out the power going to the ignition coil, the fuel pump relay and the positive side of the fuel injectors (which are controlled by the PCM by providing ground individually to each of them). The other side of the coil for the ASD relay is connected to the PCM and gets ground when the motor is running or it rotates (when you crank it for example), if the ASD relay has no power then there's no fuel or spark. You can do this at the ignition key but in that case it does not account for being "jumped" by a thief
EDIT: like he ^ said
the ASD relay is in the PDC by the battery, you have 12v in the run and crank position to it and ground given by the PCM on the coil side. fairly simple to do, on a '95YJ the +12v keyed is white with yellow stripe (EDIT: actually it's dark blue color for the +12v ASD coil side according to the '95 FSM), not sure if that's the same on a 93 or not.
« Last Edit: March 06, 2012, 05:51:10 PM by sharpxmen »
