Author Topic: No horn - HELP!  (Read 4017 times)
No horn - HELP!
« on: March 10, 2012, 03:34:31 PM »
Ok, so my horn officially died, and it is nmot the horn itself, because I already replaced that.  It seems the problem is the contact on the steering wheel, but I have NO IDEA how to fix that.  Any ideas on how to fix this (other than installing a new HORN SWITCH or BUTTON!)?
Re: No horn - HELP!
« Reply #1 on: March 10, 2012, 03:54:21 PM »
When you do find the Problem please E-mail me to let me know.  I pulled the steering wheel pulled apart the contact plate cleaned every thing and still nothing,
Re: No horn - HELP!
« Reply #2 on: March 10, 2012, 05:00:23 PM »
Take the horn botton off.  Inside you'll find how the horn works.  There are three screws that hold a plastic ring.  Under it is a contact.  Clean the contact.  Be careful as you can get shocked if you leave the battery connected.
yjwrangler91
Re: No horn - HELP!
« Reply #3 on: March 10, 2012, 05:52:57 PM »
Hi i had that horn problem i had a bad relay under the dash on the drivers side above the e brake hope this helps
Re: No horn - HELP!
« Reply #4 on: March 10, 2012, 07:54:31 PM »
By "horn button" you mean the Jeep logo"  Mine came without it...  But I have never seen the 3 screws.
Interesting...  I'll take a look at that before taking my steering wheel apart!
Re: No horn - HELP!
« Reply #5 on: March 10, 2012, 10:10:03 PM »
i think there'a also a fuse, and if you didn't check put a jumper cable straight to the horn to make sure it's not shot.
Re: No horn - HELP!
« Reply #6 on: March 10, 2012, 10:26:23 PM »
Know I'm not getting any spark to the Button/ contact.  So guess I need to find that relay.  Fuze is good.
Re: No horn - HELP!
« Reply #7 on: March 11, 2012, 09:25:34 AM »
I know it is not the fuse because it worked on and off before it died.  But it certainly sounds like either a bad relay or a bad contact...  I will start with the relay because of simplicity, and the look at the contact.  As for the horn itself, I replaced that thinking it was damaged by water or something, so the one there is new...
Re: No horn - HELP!
« Reply #8 on: March 11, 2012, 11:55:03 AM »
Dumb question is the windshield washer tied in any way to the Horn.  Cause that Died on mine at about the same time.  Have put in a new washer Motor but am not getting juice to that either.
yjwrangler91
Re: No horn - HELP!
« Reply #9 on: March 11, 2012, 01:15:21 PM »
By the wiring digrams they come off the ing switch together and split from there .
Re: No horn - HELP!
« Reply #10 on: March 11, 2012, 01:15:43 PM »
Just foun the section on the FSM...  8G...
Re: No horn - HELP!
« Reply #11 on: March 11, 2012, 01:37:49 PM »
« Last Edit: March 11, 2012, 01:40:38 PM by Jeffy »
Re: No horn - HELP!
« Reply #12 on: March 11, 2012, 03:03:31 PM »
Must be a aftermarket steering wheel?
The pic is the stock one, I've had 2 different jeep wheels but both used the same internals...
Re: No horn - HELP!
« Reply #13 on: March 11, 2012, 04:51:02 PM »
No, I meant the Jeep logo in the middle of the part that Jeffy took off for that picture (you can see it in the background).  I still need to pull out the horn straight up.  Any ideas on how to best do that?
Re: No horn - HELP!
« Reply #14 on: March 11, 2012, 05:04:54 PM »
You NEED a puller to remove the wheel. Its Mother to get off with out one.
Most cheap tool and auto-parts stores sell them for under 20 bucks.
The other thing that goes wrong is the rign or the brush wear out and dont make contact anymore.
